Sponsored by: Kumho
Valve stem pressure indicators
Old Dec 1, 2003 | 11:21 PM
TallPaul's Avatar
TallPaul
Pep Boys sells these things that screw onto your tire valve stem and apparently give you an at-a-glance indication if the tire pressure is off. Are they any good? Cost $10 each on sale. Wonder if they could go bad and actually let the air out of your tire?
Old Dec 2, 2003 | 09:28 PM
NoMo's Avatar
NoMo
If you decide to buy, be sure to get the ones rated for your correct air pressure.
Old Dec 3, 2003 | 05:22 PM
Knobby4604X4's Avatar
Knobby4604X4
My brother had a set on the throwaway car he used to commute to school. He never had a problem with air escaping, but the pressure 'reading' was always off. The set he had was supposed to indicate green at approx. 32 psi, but the caps would show green even when the tire only had 15 psi in it. I would save the money and manually check them. Not hard to remember if you make it part of your gas up routine - fill gas, check oil, check air, and get coffee. The last step is optional
Old Dec 3, 2003 | 10:17 PM
TallPaul's Avatar
TallPaul
Thanks all. I looked at them, Tire Minders I think they are called. Actually they are $10 for 4 of them. I think they are too cheaply made to be very accurate (thanks for confirming that Knobby). Guess I can do better eyeballing the tires. But yeah, I should check them often. Just one of those things that is a chore. I'd much rather check the oil. I am not going to get the tire minders because I have this strange feeling that if I do, Murphy's law is going to get me and they will leak the air out of my tires at the worst possible time.
Old Dec 6, 2003 | 12:36 PM
JohnBoy2's Avatar
JohnBoy2
I have them on two cars, and one truck. I just checked the two cars, and just like reported above, they aren't very accurate.
I will continue to leave them on, as they can alert to a sudden and drastic air loss. But, in no way should they replace periodic checks with a good guage.
donsor
1983 - 2012 Ranger & B-Series
13
May 27, 2014 04:25 PM
qman
Nov 30, 2012 08:34 PM
Barrie guy
6.7L Power Stroke Diesel
May 1, 2012 12:33 AM
F250GO43
May 20, 2008 04:29 PM
PHWLEE
Dec 1, 2006 07:42 AM
