Aerostar Ford Aerostar
93 Aerostar Clock Spring
Old Dec 1, 2003 | 10:05 PM
ast1960's Avatar
ast1960
This may be a topic that has been re-hashed here before but I thought it worth mentioning. If your horn and cruise control quit working and the airbag caution light flashes, it is most definitely the clock spring assembly is defective. I tore into my 93 Aerostar steering column this past weekend. I jumpered around the clock spring and got the horn to work. Next, checked continuity from the two steering wheel connectors (one for the airbag and one for the horn and CC) to the connectors at the lower end of the steering column. Zilch!
Next was to inspect the clock spring assy ribbon cable. Here in lies the problem gentleman. After many years and miles of the steering wheel turning left and right, the ribbon cable some how got caught and bent over 180° and crimped. It must have did this over and over because the cruise control problem started out to be intermittent. As the ribbon cable continued to be crimped, the circuit failed.
If you don't want to pay a Ford dealer $110 for a new clock spring assy, it can be repaired. I remember seeing a post on this board where someone was saying they can't be repaired. It can be repaired with the right tools and wiring knowledge. It is just a matter of disassembling the two clock spring connectors, cutting out the crimped portion of ribbon cable and putting it all back together.
Hot dam, I've got my cruise control back!!
Old Dec 3, 2003 | 07:25 PM
ast1960's Avatar
ast1960
(Was just trying to share bump)
I guess I'll stick to reading the threads in here! Maybe clock spring failure on an Aerostar is not a common problem.
Old Dec 4, 2003 | 06:45 AM
rlmdad's Avatar
rlmdad
ast1960,
Clock spring failures can be the root cause of numerous problems from horn, cruise control and/or the air bag system. It is nice to know that it is possible to repair the ribbon cable if indeed it has been broken and your post is greatly appreciated.
When posting informational threads, don't be surprised if you don't seem to receive a lot of replies. Check out the views. We may not always reply to threads that don't need help, but we certainly view them to gain more knowledge from our fellow forum members.
Happy holiday's to you and yours.
Ron
Sunline Fan
Aug 23, 2022 06:13 AM
mitch_c
Electrical Systems/Wiring
Aug 15, 2011 08:11 AM
taylormade99
15
Oct 27, 2006 10:22 AM
