1978 - 1996 Big Bronco
1993 Bronco
Old Dec 1, 2003 | 09:23 PM
melandanne's Avatar
melandanne
Unhappy 1993 Bronco
I really need help. Heres the problem.
I drive about an hour the the store on my way home about 45 minutes my truck starts to choke. looses power and I slowly come to a stop it still idles but its choking. It acts like it needs fuel. we have done a tune up , we changed the ignition coil, map sensor, o2 senser, ignition module
We get towed and a few hours latter it starts and runs great gives no codes.
Today it did it again and we came up with two codes. 412 &172
Idle speed and o2 sensor.
any help would be so great
Old Dec 1, 2003 | 10:05 PM
AYoungblood's Avatar
AYoungblood
Maybe fuel pump is over heating?
Not sure on other codes, dont see why they would cause that.
Old Dec 1, 2003 | 10:31 PM
bronco351's Avatar
bronco351
Did you change your fuel filter? If not you should!!
Old Dec 1, 2003 | 11:10 PM
melandanne's Avatar
melandanne
The fuel pump seems to be making more noise latey.
Its never been that loud. Is it a sign that the fuel pump
is going to go. Both the noise and over heating?
Thank You So Much
Old Dec 1, 2003 | 11:12 PM
melandanne's Avatar
melandanne
Yes. not to long ago.
Thank You so Much
Old Dec 2, 2003 | 01:53 AM
rlh's Avatar
rlh
I vaguely remeber some Broncos around that time had issues with fuel pressure regulation. As I recall though the usually just wouldn't start.
