Ccv relocated
Old Nov 26, 2024 | 06:26 PM
Bohen's Avatar
Bohen
Ccv relocated
So currently I have.It going to the atmosphere underneath the cab.But I'm costing around the idea of actually having it go in to my downpipe.What do I need to be aware of if I go through this route?
I don't mind the smell my wife does when she drives the truck though that is very rare.
Thanks 🤙
Old Nov 26, 2024 | 07:59 PM
Just Chilling's Avatar
Just Chilling
Does she get nervous driving the truck?….
sorry my mind just took a turn when reading that sentence.
So to your question, you may cause more dpf burn offs putting that junk back in the exhaust or worse plug it up and or foul some sensors.
Old Nov 27, 2024 | 07:14 AM
speakerfritz's Avatar
speakerfritz
What do you mean down pipe
mine is run to the rear bumper using a 20 ft 1” hose
Old Nov 27, 2024 | 07:37 AM
jimzpsd's Avatar
jimzpsd
Many folks will tap into the exhaust to assist in drawing out the gases for your exact reason, however it must be done behind/after the DPF as not to foul out the sensors, etc.,............. tail pipe over the axle typically.
https://www.ebay.com/itm/30292683955...kaArLAEALw_wcB
Old Nov 27, 2024 | 07:53 AM
WXboy's Avatar
WXboy
I would remove it and install the 23+ Motorcraft CCV box. It'll remove all the smell, last for 100k miles or more, provide the correct vacuum/flow that was engineered into the engine design, and won't leak on your driveway.
Old Nov 27, 2024 | 08:08 AM
Overkill2's Avatar
Overkill2
Gentlemen, I believe his truck is on a diet and lost weight...
Old Nov 27, 2024 | 09:12 AM
ztodd377's Avatar
ztodd377
What’s different about the 23+ over the 22 and older? Is it also a direct fit?
Old Nov 27, 2024 | 09:43 AM
jimzpsd's Avatar
jimzpsd
Once again, the whole idea of a ccv reroute is to put a stop to the oily gases going back into the engine. With the newer ccv version it will dump all the crud back into the engine. Why go back to that method if he already rerouted? And the factory ccv box has nothing to do with "vacuum or flow"........... its simply a mandated EPA device to reburn spent gases. The newer version is as simple as the earlier non filtered element, its non serviceable but does the same thing, dumps back to the engine.
Old Nov 27, 2024 | 09:59 AM
Great Danes's Avatar
Great Danes
Best bet is to route it to a cheap catch can and then vent the can to the atmosphere somewhere near the rear axle. The can prevents any drips on the driveway and the smell is greatly reduced as well... any smell that does exist will be at the back of the truck.
If the truck is truly on a diet, then the exhaust smell is much stronger anyway.
Old Nov 27, 2024 | 11:20 AM
jimzpsd's Avatar
jimzpsd
I was just assuming its stock and making a recommendation.
Old Nov 27, 2024 | 04:12 PM
Bohen's Avatar
Bohen
Sorry, I forgot to mention.It is on a diet my truck.lol
Old Nov 27, 2024 | 04:14 PM
Bohen's Avatar
Bohen
I forgot to mention my truck is a 2013 still low miles 33543 i've done alot for preventive maintenance.
Old Nov 27, 2024 | 04:23 PM
Overkill2's Avatar
Overkill2
Np, I was just passing on additional info...
Old Nov 29, 2024 | 07:37 AM
Walleye Hunter's Avatar
Walleye Hunter
I'd like to hear more on this matter. I've heard and understand that some sort of CCV mod is in order. I don't know that I like idea of rerouting it but what is it about the later CCV that's acceptable vs the factory one? Truck is a 2019.
Old Nov 29, 2024 | 07:57 AM
speakerfritz
later ccv ‘s don’t have a replaceable filter media
any ford ccv is going to drip back to the crank case captured fuel gases which will dilute your oil
any ford ccv is going to send oil vapors to your intake and these vapors have heavy metals which damage emissions systems.
