Cylinder contribution test
Old Nov 26, 2024 | 05:52 AM
deanramey's Avatar
deanramey
When I start my truck, I see 2 distinctly different colors of smoke from the exhaust, black and a light grey/blueish colored smoke. The blueish/grey smoke goes away after the truck warms up. The black smoke is there when accelerating heavily. I've also noticed the coolant level in the reservoir decrease ever so slightly.
I attempted to run the cylinder contribution test and every time I do the engine stops running and ForScan tells me the test completed and no errors were found. Is this normal?
Old Nov 26, 2024 | 07:03 AM
Pikachu's Avatar
Pikachu
It's not normal for the engine to die, no.
Old Nov 26, 2024 | 08:46 AM
udsuth78's Avatar
udsuth78
What truck is it you've got? I've had similar behavior out of an E99. I always chalked it up to the one off PCM redheaded stepchild that is an E99. I'd be more concerned about the smoke than the CCT, that test is just a hairs breath above utterly useless. what mods have been done to this truck? Tuning can be the difference between a well mannered truck and an obnoxious PITA. The grey/blue at start up isn't too concerning as long as it's just a little haze and not mosquito fogger. The black is raw fuel most likely and shouldn't ever be there except under very hard acceleration.
Old Nov 26, 2024 | 08:49 AM
Pikachu's Avatar
Pikachu
Mine is also an early 99 and it does not die after the CCT completes. At least it didn't last time I ran it. It's possible an update to ForScan could have changed that by adding a glitch.
Old Nov 26, 2024 | 08:58 AM
udsuth78's Avatar
udsuth78
Mine doesn't do it all the time but some times I can't run a cct without it killing the truck or Forscan locking up and forcing me to reboot. Some times in the rain simply trying to connect Forscan will kill the truck. I've pulled the PCM and IDM multiple times looking for any signs of water damage and even swapped both for known good parts and never any difference. Again I just figured it was quirky E99 BS.
Old Nov 26, 2024 | 07:24 PM
deanramey's Avatar
deanramey
What happened to our signatures? All of my mods are listed in my signature. I, too, am dealing with an E99 truck but it is extensively modified. I have a hard time listing all of the mods without referring to my signature on here.
Old Nov 26, 2024 | 08:02 PM
deanramey's Avatar
deanramey
How long does the CCT test appear to take to run to completion? My test appears to only last about a couple seconds, MAX. No more than 3 seconds before I get the described results. And having been a few days since I've tried running this test, 3 seconds seems like a long time.
Old Nov 26, 2024 | 09:21 PM
John in OkieLand's Avatar
John in OkieLand
must be your Browser?
__________________
E99 F250 (20 Jan 98) CCLB 2WD, 238/100 injectors, T500 HPOP, KC300X 66/73 E99 Turbo, EBPV delete pedestal, Beehive valve springs, Airdog II fuel system, CNC Fab 4 line fuel feed with fuel bowl delete block, bellowed up pipes, MBRP 4" turbo back exhaust, 6637 air filter and 4" intake, CCV mod, 4.7V Zener diode in MAP circuit, Wyse Stage II trans, 6.0 trans cooler, Hydra w/PHP and 1023 tunes, CNC Fab HPOP lines with HPX, EGT/Boost/Fuel Pressure gauges, 08-16 Power fold/Power extend tow mirrors, 128K miles
Old Nov 26, 2024 | 09:25 PM
udsuth78's Avatar
udsuth78
Never timed it or anything but I'd guess between 15 and 30 seconds.
Man that's weird, this morning on my laptop you had no signature but now there's a freakin novel. Huh
Old Nov 27, 2024 | 08:41 AM
deanramey's Avatar
deanramey
That is weird. I don't see any signatures anywhere in this thread except at the bottom of John's post and that's my signature at the bottom of his post. It must be my browser on this Samsung Android phone.
Old Nov 27, 2024 | 08:45 AM
Pikachu's Avatar
Pikachu
I can only see signatures on the desktop site. Mobile browser is a hard nope. He copy/pasted your signature into the message body. That's the only reason I can see it.
Would be nice if signatures could be turned on for mobile browsers (hint, hint).
Old Nov 27, 2024 | 08:46 AM
udsuth78's Avatar
udsuth78
The mobile version doesn't show signatures unless you download the app and even then it seems some people still don't see them. You can double check your settings though just to make sure
Old Nov 27, 2024 | 08:57 AM
deanramey's Avatar
deanramey
I am using the app and I've looked through all the settings I can find and I still don't see any way to show signatures while using a mobile app. So be it.
Old Nov 27, 2024 | 09:11 AM
deanramey's Avatar
deanramey
I've now logged in on my work computer and I see signatures at the bottom of every post in this thread except my initial post and every post from udsuth78. I wonder why the mobile platforms don't show the signatures. Maybe they would take up too much of the small screen space.
Old Nov 27, 2024 | 10:28 AM
Pikachu's Avatar
Pikachu
That and bandwidth were considerations.
In 2007 . . .
