Issues with trans or diffs try this....please read
Old Nov 25, 2024 | 07:34 PM
Dustin F450's Avatar
Dustin F450
If you buy a new truck, for the love of God check ALL the fluids including the trans and differentials. I'd Wager that 70% of the transmission "bumps" or other issue are underfilled transmissions. The whining, noises and grinding noises that people say come from differentials on these forums....posts seem like they would be solved right from the beginning if you checked your differential gear oil. Don't be lazy. DO NOT EXPECT the dealer to do it as part of a pdi, they wont....trust me, I've experienced it.
Old Nov 25, 2024 | 11:41 PM
Louisville Joe's Avatar
Louisville Joe
Good advice. I always check every fluid level in a new truck, at work and at home. Grease them too, that is the trucks that still have zerk fittings.....
Old Nov 26, 2024 | 04:52 PM
the1adman's Avatar
the1adman
I absolutely agree and always do. I did on my new 24, except the transmission. The transmission fluid is not so easy to check.
Old Nov 26, 2024 | 05:05 PM
Dustin F450
On 24' don't you just get it to 205* iish and loosen the standpipe plug, if it dribbles,it's full if not pull the plug on the passanger side of the case, burn your arm...cuss a bit and pump in fluid until it dribbles out the loosened plug pn tnr pan. Easy peazy
bsm2003
May 15, 2010 03:08 PM
crazymut
Nov 16, 2009 08:59 PM
jethro
Sep 23, 2001 08:34 PM
