Sponsored by: Auxito
Fuel pump?
Old Nov 25, 2024 | 05:56 PM
LouieTheLizard's Avatar
LouieTheLizard
2nd Gear
Fuel pump?
2003 F150 4.6 triton, fuel injected . Turns over, but won't start.. Had to replace fuel pump a year ago with same symptoms. Do I need to replace pump again?
Old Nov 25, 2024 | 07:00 PM
BareBonesXL's Avatar
BareBonesXL
Could be several different causes. Check fuel pressure.
"Turns over, won't start" is not very detailed. What is the THEFT light doing?
Old Nov 25, 2024 | 07:46 PM
LouieTheLizard
2nd Gear
Theft light quickly flashes. About 2 per second.
Old Nov 25, 2024 | 08:12 PM
BareBonesXL
Sounds like a PATS problem, that's what the light does when the wrong key is tried. Make sure that you have the correct chipped key, and no other large metal objects or other chipped keys are on your key ring. Let the light settle down (takes about 15 minutes after using the wrong key) to one flash every two seconds, normal operation, and try again,
rondawgg1118
Feb 11, 2007 09:30 PM
