Battery with Solar set up help
Old Nov 19, 2024 | 09:08 PM
SPS573's Avatar
SPS573
Hello All,
2000 Ford Excursion 6.8 V10 4x4 here.
My Optima red top just failed on me after about 3 1/2 years. Pfft. My old Optima I had for over 10 years…. So anyway I decided to order an Odyssey Extreme battery. Debating on trying to run a dual battery and a solar panel on the roof rack. Anyone have recommendations for this? How big should the solar panel be? Thinking of running a 2000W power inverter as well. From what I’ve seen that should be plenty for a small fridge and charging power tool batteries? Thanks!
Old Nov 19, 2024 | 09:19 PM
John in OkieLand's Avatar
John in OkieLand
if the Solar panel can output 4 amps, you are Golden.
I use a 4.5 Amp on my Excursion, and it will top up the batteries from 12.05 to 13.3 in about 3, maybe 4 hours...
Being Solar, it would top them off every day, when the sun is available.
Old Dec 29, 2024 | 10:09 PM
truck7575's Avatar
truck7575
Can you say what type of solar setup you're running with specifics?
predfan4life
Sep 18, 2023 12:54 PM
oresto
Jul 8, 2023 07:30 PM
Smoking Joe
Jul 5, 2021 10:02 AM
HRTKD
All Things Towing
16
Feb 17, 2018 10:15 AM
IDMooseMan
All Things Towing
29
Nov 27, 2008 08:37 PM
