Water Leak
Old Nov 14, 2024 | 12:43 PM
Realwickedone's Avatar
Realwickedone
Water Leak
Okay Son has 2017 F 350 Superduty crew cab short box with the dreaded full size sunroof...he has developed a water leak the front and back floor is WET...other than the obvious places....that damn roof...possible windshield cowl around the door seals...any other place we should look truck sits alot...
THANKS...
Old Nov 14, 2024 | 06:18 PM
dieseldrew's Avatar
dieseldrew
Cab lights if it has them.
Old Nov 15, 2024 | 06:54 PM
HarveyTruck's Avatar
HarveyTruck
Cab vents on rear of cab.
moonroof drains and tubes on corners.
Roof seams on top of cab. The body sealer can fail over time. Even a tiny crack will leak.
Fresh air intake on passenger side. Cowl drainage issues can over top it.
The drainage outlets under the truck can get clogged with crud over time.
If you’re having water leaks in the rear of the cab vents are a prime suspect.
Old Nov 17, 2024 | 07:35 PM
Overkill2's Avatar
Overkill2
I'd check the seal around the rear 3rd brake light housing. I had a leak on mine and so did my buddy on his 19 F350. Found good housing seals on Amazon.
x2 on the cab lights as well...
Old Nov 25, 2024 | 12:42 AM
NVairborne's Avatar
NVairborne
5th Gear
Drain tube above headliner where sun visor mounts. Take off visor and pillar trim and slightly pull down, a drain tube know to disconnect. Hope this helps.
2018 f250
2021+ F150
Dec 29, 2023 10:53 AM
Big Red
Apr 27, 2005 11:51 AM
dcale101
1983 - 2012 Ranger & B-Series
Sep 1, 2004 07:10 PM
