96 f150 code p0102-MAF circuit low
Old Nov 11, 2024 | 07:41 PM
LilBrussel23's Avatar
LilBrussel23
4th Gear
I just got this 96 f150 I6, had an engine code listed above since I got it. I'm now at a loss on what's wrong. Cleaned the maf, replaced maf, checked for vacuum leaks. The code still is there. Cleared it after replacing the sensor, and it came back. Tested the sensor plug to pcm, no issues there. Swapped it for a sensor I know works, and was still reading 0lbs of air movement. Put the sensor back the vehicle it came off of, and it read normal air movement. Unplugged the MAF sensor started it and the light went off. Any advice for further diagnostics?
cj45lc
6.7L Power Stroke Diesel
Sep 20, 2022 01:43 PM
cj45lc
Sep 18, 2022 09:40 PM
Pcompton
28
Feb 7, 2022 04:05 PM
Fordenthusiasts
Aug 27, 2008 09:30 PM
huckster
Modular V8 (4.6L, 5.4L)
Sep 12, 2003 11:26 PM
