2004 ford ranger engine swap compatibility??
Old Nov 10, 2024 | 04:12 PM
Hfulton1990's Avatar
Hfulton1990
1st Gear
I have a 2004 Ford Ranger and it requires a 3.0 engine. I was curious on what other vehicles are compatible with this truck. My truck is 2wd
Old Nov 10, 2024 | 06:39 PM
Johnny Paycheck's Avatar
Johnny Paycheck
‘04-06 is listed as a direct swap.
Other years around that may work, but likely involve swapping accessories, sensors, intake to make things work.
Old Nov 11, 2024 | 06:58 AM
TopsailBeachBum's Avatar
TopsailBeachBum
So close and yet so far: how about what is compatible with 2007 3.0 engines?
Old Nov 11, 2024 | 10:36 AM
Conanski's Avatar
Conanski
I replaced the 3.0L engine in the 04 Ranger we acquired quite a few years ago. The #1 rule of engine swaps is do not use any wiring that comes with a donor engine because Ford is notorious for changing connector pinouts and wiring colors and because the same engine will have vastly different wiring in different vehicles, so it almost doesn't matter what vehicle it come out of.. you have to strip it down and transfer stuff from the old engine. That applies to accessory brackets, engine mounts, exhaust manifolds, and even the intake manifold, so it's always best to source an engine from another Ranger to minimize the work needed.
f15098
Oct 19, 2021 07:08 PM
Ezploren
Engine Swaps
Aug 16, 2020 06:20 PM
1024kt
Feb 5, 2015 11:38 AM
poorfatkid
Sep 21, 2012 10:52 AM
