Anyone have the Ford OEM UnderCover hard one-piece tonneau cover? What are your overall thoughts? Wondering if it will obstruct your view from the rear window or have any other issues.
I'm thinking about getting one. Prefer it to other tonneau covers, but it's also a large item and once bought, don't want to end up storing in the garage because of unforeseen issues.
I have it and it's basically the Backflip MX4 with a Ford logo. I really like these covers and have had the Backflip MX4 on my last few trucks. I have a long bed so three panels out of four can be opened and latched down. The fourth panel rests again the rear window for access to bed items but cannot be used in motion like that. So, with three open I can clearly see my fifth wheel hitch. Short beds get a three panel I think so I don't know how much bed is available with just two panels open. If you need the whole bed available in motion, this is not for you.
Thanks. The Bakflip one is actually flush with the bed from what it looks like. The one I'm looking at is the one-piece, which sits on top of the bed rails. Hence, wondering if it'll be annoying by obstructing the rear window in any way.
Not using the bed for much from wanting that type of topper. When you want to use the bed for larger or taller items, you have to remove it, as it only comes up so much. That image above, basically that is it.
No, that won't obstruct your view when down. Yes, you will see less it it's raised a bit. This type of one piece cover is not used in motion IMO. I never considered this type so I am assuming.
