Code 172 after O2 replacement
I read the code from my 93 F150,4X4, 351 and it was 172 (lean). The truck has 112K miles and the O2 sensor has never been changed so I replaced it. After a few weeks the code came back.
I was going to check the fuel pressure over the weekend but only have the GM connector on my fuel gauge. Since it is relatively easy, I replaced the fuel filter since it had been awhile and I still have the 172 code. I had my fuel pump replaced about 2 years ago. Has anyone had this problem? Is the next step to test the fuel pressure?
The truck runs fine and gets about 15 miles/gal. The code only comes on after about 8 miles of driving and stays on until the truck is shut down. I never seem to get lucky just replacing parts and I'm up to my ears in wrenching on my Vette. Can anyone let me know what worked for them?
I have an aftermarket chip in the truck for whatever it's worth. I'm sure not many parameters where changed since the only mods made where true dual exhaust and FIPK by K&N.
Thanks, Beth
not the best way to check and see if it fixed it completly.
