Sponsored by: Kumho
Steering Column Squeek
Old Dec 1, 2003 | 09:01 AM
naper's Avatar
naper
Question Steering Column Squeek
1997 F150 2X4 .What is the cause of a squeek in the steering column it is worse when cold? Is there an easy Fix?
Old Dec 8, 2003 | 10:12 PM
stevorino's Avatar
stevorino
Good news. I don't know if you've figured it out yet but I had the same problem and the solution was tightening up the two big bolts that hold the steering column tight against the underside of the dash. There is a big aluminum bracket that snugs up the column with two black bolts. Tighten them up and it should go away. Good Luck!
Old Dec 8, 2003 | 10:14 PM
stevorino's Avatar
stevorino
OOps you're truck is much newer than mine. maybe it still similar. Sounds like a loese bolt with the temperature thing.
