I have a 360 right now with a c6 tranny... Im putting a 302 with an aod tranny in, I was wondering if there was a conversion kit to put the c6 on the 302 or anything like that to where i could put the c6 on the 302.... If not, i will just put the aod tranny in... I was just thinking it is going to be a pain to put the aod in, plus if i ever need to tow anything.... well you get what im saying... but i guess it works both ways cuz i will get better mpg with the c6... and i was wondering if i could put a c6 on the 302 if there was a torque converter i could put on, im just asking cuz doesnt that give you better mpg?? thanks
why would the c6 give you better gas mileage. the aod has overdrive where the c6 only has 3 gears so the aod would give better mileage. a torque convertor is something like a clutch in a manual tranny, it turns when enough gas is applied.
