4r100 problem
Old Nov 2, 2024 | 09:06 PM
Bill Owen's Avatar
Bill Owen
Trailering
4r100 problem
Hi my name is Bill Owen, I am new to this forum and in search of solving My 4R100 trans problem. I recently rebult this trans and installed a Tugger kit. The problem is, is my truck(1999 7.3 F350 2wdr dually) starts out in 2nd gear, ever when I manually shift to first. The error code is P0781 1 2 shift error. Ive done almost everything. tried 2 different shift solenoid pack: changed all sensors: went through trans harness took apart and inspected the harness and plug ends: checked power and contentnuity from the pcm to the trans (all checked good); changed eccelerator pedal; went through the valve body and accumulator valve for stuck valves; and there is much more that Ive done to no avail. I just cant figure it out. Im about to pull it again and go through it to see if i can find what is wrong. The enitial reason for repair was burnt forward clutches in the forward drum, no first gear. Hopefully I can get some help here. Thanks
Old Nov 2, 2024 | 09:22 PM
Papa Tiger's Avatar
Papa Tiger
Welcome Bill.
Check it out? 4R100 Transmission slow to engage 1st gear - Ford Truck Enthusiasts Forums
Old Nov 2, 2024 | 09:43 PM
Bill Owen's Avatar
Bill Owen
Trailering
thanks PaPa Tiger, Im not sure that applies to my situation. I dont have first gear it is not slow to start. I put gear shift in low and it takes off in second. there is no shift to second. The computor is commanding the shift but you dont feel a shift
Old Nov 2, 2024 | 10:14 PM
Papa Tiger's Avatar
Papa Tiger
4r100 Transmission Diagram ← most likely that is put together wrong or stuck.
Old Nov 3, 2024 | 07:07 AM
Bill Owen's Avatar
Bill Owen
Trailering
I had a trans shop check that and the accumulator valve out to see if Ive done anything wrong, He said everything looks fine and that it should work. But the trans still did the same thing. Today I plan on pressure checking the clutches; because i failed to do that after the rebuild. I will go over the valve body as well.
Old Nov 3, 2024 | 07:13 AM
Bill Owen's Avatar
Bill Owen
Trailering
Papa Tiger I will double check the low reverse valve today sometime. Thanks
Old Nov 4, 2024 | 12:03 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
You might want to start a new thread for this over in the "Clutch, Transmission, Differential, Axle & Transfer Case" forum for this.
Welcome aboard!
Old Nov 4, 2024 | 05:59 AM
Bill Owen's Avatar
Bill Owen
Trailering
ok thanks. ill do that
FN250super cab
New Member Introductions
May 10, 2025 04:37 PM
Thebucks
Oct 31, 2022 10:13 PM
ConstantSorrow
Sep 19, 2021 10:11 PM
