need more power again and again
i think if you have 3.73 and u still boge down i think its time for a new motor i got a 300 with 3.55,33.12.50 and i can pull digg sling turn what every you what to call it.
i got a 78 150 4x4. that im giving up the 9" in it to keep my 8.8 pois. i went out today and went more places than 4x4 and im 2x4 so if you r scard let me nkown i might cut ut saome slack. you gus are a bunch or nerds if you buildm a bick ind one week and still gett your money call me bitch if you want thio
One other way to get a rough guessament would be to jack up the rear end both wheels off ground if it's a posi only one if it's open .. Make a mark on the drive shaft put tranny in neutral and spin tire one complete rev. count how many turn the drive shaft make. 3 1/2 turn makes it 3.50 Gears 4 plus a little more turns makes it 4.10.
ShaZam
ShaZam
#29
instead of re gearing, you could just get 31" tires, that way if your tread is a bit old, you can sort of kill two birds with one stone.
the bigger tires will give you more grip, and also lower(or raise... whichever way you look at it) your final ratio. I have a 3.55 and 31" tires, it still accelerates pretty well for a pickup, and the highway is fine if you stick with the speed limit. She'll cruise at 70-75mph, but it requires a lot more pedal than a simple 60-65. it seems that 55mph is the sweet spot in OD.
#30
im running a 88 f-150 XLT lariat 4X4 regular cab standard box with the 300 6. i bought the truck for 500 bucks after the previous owner ran it out of oil and ive run it about 2 years since and im overhauling it and getting it bored .030and was considering a performance cam to give it alittle more snuff...if i put a performance cam in it will i also need to adjust or replace the computer chip that controlls the timing? if anyone could help me out i would realy appreciate it. thanx
