Shifter
Old Oct 26, 2024 | 05:48 PM
keenem68's Avatar
keenem68
7th Gear
Shifter
Looking for info on removing the shifter from a 4 speed top loader transmission. I want to leave the tranny on the engine when i put it back in my m68 truck. Thank's
Old Oct 26, 2024 | 06:35 PM
85e150's Avatar
85e150
Is it the Ford performance "top loader" from a '60s car?
Or an OEM type top loaded, top shifted transmission?
The stick will come out of the older OEM type, but it depends on what it is as to how the cap comes off.
The '60s trans may require the whole shifter to come off. Some had removeable sticks, some did not.
Can you pull the boot and flooring back to see more details?
Old Oct 27, 2024 | 10:08 AM
lshort's Avatar
lshort
On the ones that I have the shifter handle is not removable from the shifter
To remove the whole thing Just remove the 2 mounting bolts and the nuts from the 3 shifter shafts noting the orientation of the 3 little tabs because you can reverse them.
i
Old Oct 28, 2024 | 02:19 AM
f1up's Avatar
f1up
Are you referring to a 4-spd top loader car transmission like out of a 60s model car, or are you referring to the 'bulldog' 4-spd truck type transmission. Some people mistakenly refer to the 'bulldog' as a 'top loader'.
Old Oct 28, 2024 | 05:18 AM
55RoundTwo's Avatar
55RoundTwo
It appears that more information would be helpful. Do you know the make/model of your transmission? As already indicated, transmissions other than the actual toploader were mistakenly referred to as toploaders.
01CRAZY_COOTER01
1997 - 2003 F150
Jul 1, 2008 09:12 PM
59'er F100
Mar 15, 2007 05:15 PM
