460 timing/pinging
Old Nov 30, 2003 | 11:48 PM
JerichoM1070's Avatar
JerichoM1070
460 timing/pinging
I recently developed some pinging under load and acceleration in my '88 F350 460. I was under the impression that I'd turn the distributor one way or the other, but I can't get it to move.
Can anyone tell me how to set the timing? I think it's EFI IV or something like that. I hear I may need to disconect something to adjust it properly but I still don't know what's going on - things were simpler on my old 428...
Thanks for any help you can offer.
Old Dec 1, 2003 | 11:18 AM
65f100CoryE.'s Avatar
65f100CoryE.
Timming it should be the same as the old stuff. just loosen the bolt that retains the distributor in place. I think it is 1/2" head but can not rember. you will need a distributor wrench to loosen it.
especially on a newer unit like that, so much stuff in the way. hahaha other than that the timing is the same way I think it is
somewhere between TDC and -4 Deg BTDC I am not sure on the
newer 460's I on ly know the earlier ones 68 through mid 70's.
what gas are you using as well? I know the older 460's require
premie gas or it will ping like a ******* as well.
Old Dec 1, 2003 | 12:02 PM
proeliator's Avatar
proeliator
Shouldn't this be in the '385' forum? Anyways, if its a matter of your dizzy being stuck, spray some PB Blaster or anything similar around the base, let it soak, then try to rotate. Sometimes some gentle taps with a rubber mallet will be needed to persuade it.
If its suddenly pinging where none existed before it makes me wonder if there is something else wrong that retarding the ignition will simply hide....like your fi running lean or bad gas just for examples.
Old Dec 1, 2003 | 12:49 PM
JerichoM1070
Sorry about the forum - I guess I'd rather be working on my 428. Thanks for the help...
Old Dec 1, 2003 | 09:16 PM
fordeverpower's Avatar
fordeverpower
the distributors have spout connectors that you have to unplug. It should be close to the distributor.
BearFootCustom
Aug 9, 2013 09:30 PM
gring
Sep 1, 2010 07:25 AM
Shawn MacAnanny
Feb 21, 2007 10:27 AM
MPDano
15
Nov 22, 2006 06:41 PM
JQ
Nov 5, 2002 07:57 PM
