1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Carburetor damage...
Old Oct 22, 2024 | 01:24 PM
TxKnuckleBuster's Avatar
TxKnuckleBuster
The Holley 1 bbl. pictured has been damaged by improper service. The ears on the main body and the bowl cover have been over-tightened and bent. Does anyone have experience, good or bad, trying to straighten pot metal? I wondered about heating them. Another possibility would be sanding them flat, much like is done with other carbs. I need to open this carb for repair but not feeling good about those bent 60-year-old ears. Might just have to leave them alone, but with my luck it'll never seal again once disturbed.,
Old Oct 23, 2024 | 05:59 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Pot metal is brittle, usually cannot be “worked “ in my experience. I would crack it, for sure. I doubt a new/remanufactured one would set you back much.
Old Oct 24, 2024 | 04:11 PM
TxKnuckleBuster
Well, it is the original carburetor and I really don't want to replace it if I don't have to. Not likely gonna find a new one. But thanks for the input.
Old Oct 24, 2024 | 04:55 PM
Tom H So. Ca.'s Avatar
Tom H So. Ca.
The air filter wire mount like that is hard to find on most new or rebuilt carbs available. Most don't have the hole the wire goes in. Went through it a few years ago. Finally ended up with an adapter from a carb shop and bought the same carb with different filter mounting. Can't remember the name, but they are mentioned here frequently.
If you have a rebuilder near by, you might see what they have for options.
Good luck!
Tom
Old Oct 26, 2024 | 03:14 PM
1952henry's Avatar
1952henry
Search utube for a video of a fella straightening a fuel bowl surface on a 1904. He made a jig and used heat, sparingly. This is on my list to do one day, as I have several cores. Surely one would volunteer to be a test subject.
Old Nov 9, 2024 | 04:25 PM
TxKnuckleBuster
Thanks, 1952henry. Found it and it doesn't look too bad.
Harrier
Apr 24, 2024 07:46 AM
gogoat
Apr 12, 2023 11:50 PM
f1butcher
Feb 13, 2023 08:15 PM
idealtrucks
Dec 10, 2022 04:36 PM
Gary Lewis
58
Sep 27, 2014 09:44 PM
