Rear Leaf suggestion
Old Oct 21, 2024 | 10:25 AM
EX2000XLT's Avatar
EX2000XLT
5th Gear
2004 Ford Excursion Eddie Bauer 4x4 6.0L
U code front springs 43-812
KYB Monomax F250 front / Excursion rear
Stock rear springs with over leaf assist on rear half of springs.
XD Rockstar II's with 275/75r18's.
Like how front sits and ride quality.
Measurements: (Center hub to fender)
Front: 23 3/8"
Rear 23 1/2"
Looking to replace rear springs, looking for more stability and better ride. Little bit of lift from where I'm at would be okay but don't want to mess with leveling the front or replacing the U codes as I am happy with them.
I don't tow heavy, 6,000 lbs max and seldom. Excursion is DD and family hauler for vacations. 5 boys and lots of bikes (7) and luggage.
Is B code 43-1261 what I should be looking for and can I still them without adding leafs from existing springs? Thanks!
Old Oct 21, 2024 | 10:46 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
1. Neither of those codes are Ford part numbers. Those are SD Springs part numbers. Their best approximation of the Ford version.
B codes (1999-2004) and F codes (2005-2007) are the same leafs and only were offered by Ford.
SD Springs are good. Ford are good. I personally used Fords version. Plenty of people have used SD with great results. Buyers choice.
2. Height. This is extremely easy to set. Have the axle on jackstands. Install the springs loosely, then lower body until axle is holding weight. Measure. If happy, tighten it all down.
if not happy, pull the leafs back out, insert a leaf. The guides in the Sticky section have pictures showing how we’ve done this. It’s easy.
then repeat. Once you have a happy height, tighten it all down.
you can set your height to whatever you desire.
Old Oct 21, 2024 | 10:50 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
You will end up with a little extra height using B codes. They have a higher weight capacity than your current G codes. Maybe 1” at most. Depends on how tired your leafs are after all these 20 some odd years.
Just running them alone with no modifications will be fine. The extra stiffness will help immensely. Most of us mod them for the height and/or extra weight capacity. It’s not needed for what you described
Old Oct 21, 2024 | 10:51 AM
EX2000XLT's Avatar
EX2000XLT
5th Gear
Do you know if these will sit higher than stock excursion rear springs, same or higher? Guess that is the question I am asking...thanks for the reply!
Old Oct 21, 2024 | 10:54 AM
EX2000XLT's Avatar
EX2000XLT
5th Gear
Thank you!!!
Old Oct 22, 2024 | 03:03 PM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
Before you buy springs, give a call to Junior at ATS Springs in PA. He really helped me sort out what I was looking for.
I already had RAS, so Junior set me up with their B codes. This way I can adjust my rear end height while unloaded. Installed some bags, later, and now I can adjust my loaded height with air. Best of both worlds.
Old Oct 22, 2024 | 08:38 PM
John in OkieLand's Avatar
John in OkieLand
these folks build custom springs to your specifications.
call them, and they will tell you what you need...
I see a lot of custom off road rock crawlers going to these folks.
springs 7.3L Alcan Spring
Phone: 970-241-2655 Email: sales@alcanspring.com
2242 US-6, Grand Junction, CO 81505
https://www.alcanspring.com/
Norman Williams
Nov 28, 2022 10:37 AM
CaptFX4
2004 - 2008 F150
Jan 18, 2013 05:57 PM
frdf250
Oct 26, 2009 09:27 AM
famfun
May 12, 2008 10:01 AM
GREGSCOTT
May 27, 2006 02:15 PM
