Upper plenum
Old Oct 21, 2024 | 06:21 AM
Jasontmd's Avatar
Jasontmd
1st Gear
Upper plenum
I was hoping someone could give me some insight. I have a 1990 351w efi with the 2 tube air intake going to the upper manifold. It looks like this.
Image result for 1990 f150 351w intake plenum
What I would ideally like to do is change to a setup that has the air breather in the middle. What would be involved? Would I need a different efi than what came with it? Your input is appreciated. Thanks!
Old Oct 21, 2024 | 07:37 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I’m not sure what you mean. You want the air from the air filter to go to the middle of the manifold instead of the front? If so, why?
Old Oct 21, 2024 | 07:56 AM
wwhite's Avatar
wwhite
I think you mean the vacuum distribution tube.
get another plenum or drill and tap?
Old Oct 21, 2024 | 07:57 AM
wwhite's Avatar
wwhite
Oh, maybe you mean swap from SD to MAF intake?
zero point, personal preference.
could go smoothly could be a disaster.
Old Oct 21, 2024 | 08:15 AM
My4Fordtrucks
I bought a ‘94 351W that has the relocated PCV port. Now to see what the OP is asking.
Old Oct 21, 2024 | 09:07 AM
Scndsin's Avatar
Scndsin
Pretty sure he wants single blade, center mount TB.
https://www.summitracing.com/parts/h...AaAsXrEALw_wcB
Old Oct 21, 2024 | 10:01 AM
Conanski's Avatar
Conanski
Or do you mean something like this? There were a few of these made for the 5.8 but they are getting hard to find now, the upper portion is the same for 5.0 or 5.8 it's the lower that is unique to the engine. And in case you are wondering no you can't just change the upper you have to buy a complete upper/lower set, every one of them has different port sizes and locations and different bolt patterns.
Old Oct 21, 2024 | 02:59 PM
generalee's Avatar
generalee
I thought he was referring to an earlier carb type set up with a throttle body injection setup which would be three steps back imo.
TheGageinator
22
Nov 3, 2020 10:45 AM
v8xploder
Jan 21, 2009 08:40 PM
