Getting educated on engines and replacements
Old Oct 17, 2024 | 11:55 AM
cottagefarmer's Avatar
cottagefarmer
7th Gear
Hi,
I've searched for this but is there a thread on engine sources, both rebuilt and new as options for my '65 F100 ?
Thanks, CF (Patrick)
Old Oct 17, 2024 | 12:11 PM
85e150's Avatar
85e150
Your OEM options were the 240 six, the 300 six and the 352 FE V8.
None are available "new".
Since you have a V8, you can look for rebuilt 360 or 390 engines that will pop right in.
Jasper is one source. I'll try to find others.
Do you have a local machine shop that does rebuids?
Old Oct 17, 2024 | 12:51 PM
MikeyLawless's Avatar
MikeyLawless
Your thread on the coolant leak says the current motor is a 351 Windsor? That really is a great motor with lots of aftermarket parts available. Finding another should be easy...both new crate motors as well as rebuilt. Even good used ones.
Old Oct 17, 2024 | 01:33 PM
Crop Duster's Avatar
Crop Duster
Here is a place in Tyler, TX. Mabbco Motors | Marine & Automotive Remanufactured Engines
Old Oct 19, 2024 | 11:08 PM
cottagefarmer
7th Gear
OK, I will check Jasper and some other sources as well. Thanks for providing that info. We have fixed the freeze plugs that were leak leaking. But I’m still worried about kind of long-term. So getting educated now would be a good thing. Thank you.
Old Oct 19, 2024 | 11:09 PM
cottagefarmer
7th Gear
that is correct, OK that it will be nice to know if it’s necessary. So far so good on the freeze plugs issue.
Old Oct 19, 2024 | 11:11 PM
cottagefarmer
7th Gear
Originally Posted by Crop Duster
OK, perfect, Tyler’s not far away at all. Thank you very much.
Milkacha
Apr 30, 2024 09:28 AM
pouldeau1956
Sep 30, 2022 09:41 PM
P51P28
Jan 3, 2022 09:45 AM
CameronNoble
Engine Swaps
Dec 6, 2016 05:45 PM
