E4OD Shift Solenoid Removal Question
Old Oct 13, 2024 | 06:25 PM
KWRB's Avatar
KWRB
I am removing my shift solenoid in my 1989 E4OD. I have removed all the internal torx head screws and one nut. Should it just pull down then? It's not coming easy, and I don't want to break anything.
Thanks!
Old Oct 13, 2024 | 08:04 PM
JJF20's Avatar
JJF20
I’d suspect the seal / oring is stuck in the bore.. might have to give it a little wiggle, and bump from the top. It’s plastic, old, and probably brittle, so don’t hammer on it… take your time with it. If using tools, careful you don’t scratch / gouge the bore.
David Wallace
May 15, 2021 10:29 AM
Bankrupter
Sep 2, 2011 05:47 PM
tomm211
May 15, 2008 01:10 PM
