Do I need these brackets?
Old Nov 30, 2003 | 07:18 PM
bushman's Avatar
bushman
On a 79 four wheel drive crew, Are there supposed to be brackets from the front fender corners to the frame? and am I supposed to have any outboard bumper brackets. I know the bumper bolts to the frame but was wondering if there were any brackets that went from the frame to bumper outside of the frame. Also on the fender brackets, I am using the plastic inner fenderwell. Just want to know if the brackets are used in conjunction with the plastic.
Bushman
Old Nov 30, 2003 | 07:44 PM
BigBully's Avatar
BigBully
I dont believe the brackets are used with the plastic inner fender.
and as far as I know there is no outer bumper brackets either.
Old Nov 30, 2003 | 07:45 PM
bushman's Avatar
bushman
I didn't think so. Just thought I would check
ThanksI
Old Dec 3, 2003 | 01:01 AM
oem78's Avatar
oem78
1978 and 79 do not have fender braces, but I would recomend them. Find a 1977 and take them off, bolt them up and your fenders will be very strong and won't have the tendency to bend inward. I thought the outer edge of the front bumper was a little weak and should have some kind of brace, but have never seen one. Just the four bolts to the frame.
