1978 - 1996 Big Bronco
460 Vibration
Old Oct 9, 2024 | 06:10 PM
Bostonbob1958's Avatar
Bostonbob1958
5th Gear
460 Vibration
First off thank you to all of the help you guys offer.
Ok I have a 1979 Bronco with a 69 460 in it. A few weeks ago I went to start it and a large puff of smoke blew out from under the hood I thought it caught fire there was that much. So I started it the second time just fine but there was a vibration now and it wouldn't shift out of 1st gear. I got home tranny was a little low so I filled it. Still vibrating I have checked timing, compression(130 min), spark and plugs, push rods. Now I haven't checked #1 TDC and position of rotor but looking for some possible options before I pull what little hair i have left out. ANY help is greatly appreciated thanks.
. Bob
Old Oct 10, 2024 | 08:42 AM
manicmechanic007's Avatar
manicmechanic007
If you are lucky, you just broke a valve spring or bent a pushrod
I'd pull both valve covers and take a close look
Your vibration sounds like a dead cylinder to me
You mentioned pushrods, did you inspect all of the valve springs? Closely?
Old Oct 10, 2024 | 01:33 PM
Bostonbob1958
5th Gear
ManicMechanic yes I have both valve covers off push rods were operating both up and down and spinning and springs were good. Thank you for responding.
Old Oct 10, 2024 | 07:28 PM
manicmechanic007
What ignition system are you running?
Does the 1969 460 motor have the stock Autolite 4bbl carb on it?
The breaker plate is tight?
The timing chain is not 55 years old, is it?
Old Oct 10, 2024 | 08:58 PM
Bostonbob1958
5th Gear
I've been told the engine is a 3-4 year old Jeggs rebuild
Old Oct 10, 2024 | 09:00 PM
Bostonbob1958
5th Gear
Old Oct 10, 2024 | 09:07 PM
manicmechanic007
Good, good and nice
Looks like a pretty new Duraspark distributor too
Old Oct 21, 2024 | 05:54 PM
Bostonbob1958
5th Gear
Vibration
My vibration now maybe in the transmission. With this vibration the tranny doesn't shift while in D it can manually shift but it won't go into 3rd and won't leave 1st while in D.
sanoran
16
Feb 11, 2020 09:54 PM
darren_palms
16
Aug 17, 2017 04:47 AM
cjf5150
Sep 18, 2008 02:36 AM
