Rear Universal Joints Part#
Old Oct 7, 2024 | 08:33 AM
Bronccat's Avatar
Bronccat
I'm going to WNC and in a hurry to replace rear U joints prior to trip.
Looking online is making me batty - are there only two variations of u joints for the rear DS? Or More?
I thought dbl cardan vs one piece was enough info (I have a one piece) but wanted to make sure.
Here's the Dana decal... TIA!
Old Oct 7, 2024 | 08:42 AM
Bronccat's Avatar
Bronccat
Rock auto (for example) - I assume I need to measure the yoke span?
DANA 51350X Spicer Life Series (SPL); Non-Greasable; 1.188" Bearing Cap; Outside Snap Rings Info
Fits Front Driveshaft - CV at Transfer Case; 4WD; with 1 Piece Rear Driveshaft
or Front Driveshaft at Front Axle; 4WD; with 1 Piece Rear Driveshaft
or Rear Driveshaft at Rear Axle; 4WD; 1 Piece Driveshaft; 1.188" Bearing Cap; with 4.000" O.D. Yoke Span; Outside Snap Rings
or Rear Driveshaft at Transmission; 4WD; 1 Piece Driveshaft; 1.188" Bearing Cap; with 4.000" O.D. Yoke Span; Outside Snap Rings
$21.79
DANA 51350XP Spicer Life Series (SPL) Plus; Non-Greasable; High Temperature Design; 1.188" Bearing Cap; Outside Snap Rings Info
$27.79
DANA 51410X Spicer Life Series (SPL); Non-Greasable; 4.188in Outside Snap Ring Dimension; 1.188in Bearing Cap Diameter Info
Fits Rear Driveshaft At Rear Axle; RWD; with 1 Piece Rear Driveshaft
or Rear Driveshaft At Transmission; RWD; with 1 Piece Rear Driveshaft
or Rear Driveshaft at Rear Axle; 4WD; 1 Piece Driveshaft; with 4.500 IN O.D. Yoke Span
or Rear Driveshaft at Transmission; 4WD; 1 Piece Driveshaft; with 4.500 IN O.D. Yoke Span
$27.79
DANA 514101X Spicer Life Series (SPL); Greasable; 4.188in Outside Snap Ring Dimension; 1.188in Bearing Cap Diameter Info
$32.79
DANA 51410XP Spicer Life Series (SPL) Plus; Non-Greasable; High Temperature Design; 4.188in Outside Snap Ring Dimension; 1.188in Bearing Cap Diameter Info
$34.79
Old Oct 7, 2024 | 09:08 AM
Antonm23's Avatar
Antonm23
here you go
https://venturestruckparts.com/produ...v10-or-diesel/
Buying U-joints online (especially ones sold as genuine spicer) is a mixed bag because there are A LOT of counterfeits out there. Pretty much anything on Amazon or eBay has like an 80% chance of being a fake. Venture truck parts (see link above) is good, RockAuto is usually good, but because they often ship to you directly from third parties, some of those third parties will "accidentally" let a counterfeit sneak in sometimes. So I stick with Venture truck parts for anything where I want an actual genuine spicer part (sometimes it doesn't matter , like some of the trail spares I carry in the Jeep are RockAuto "spicer" stuff).
cj3waker
Apr 29, 2024 09:17 PM
rockwind1
23
Aug 1, 2022 05:11 AM
tomkins
Apr 6, 2022 10:28 AM
mkoppler123
Dec 20, 2012 09:41 PM
