Frankenford needs some help.
Water pump - 1990 FORD F 150 Motorcraft F3TZ8501C Motorcraft Mechanical Water Pumps | Summit Racing
Radiator fan - Four Seasons 35317 Four Seasons Cooling Fan Assemblies | Summit Racing
Carb spacer - Edelbrock 8711 Edelbrock Carburetor Spacers | Summit Racing
Drag (center) link - Skyjacker Suspensions SDL250 Skyjacker Adjustable Drag Links | Summit Racing
Brake lines - 1976 FORD F-250 Skyjacker Suspensions Brake Hoses, Individual Hose & Line & Tubing Fittings & Hoses - Brake Hoses, Sets Part Type - Brake Lines, Direct Fit Part Type - Brake Lines, Universal Assemblies Part Type Parts & Accessories | Summit Racing
Plug wire holder - Summit Racing SUM-440314 Summit Racing™ Spark Plug Wire Separators | Summit Racing
This will keep you busy, pending the damage from the storm coming your way. Stay safe over there.
The way it is dirt & water when driving can be forced into the slip joint and wear it out faster.
But you got a lot more to worry about than the way the rear drive shaft was installed
I do have a question for the "ones that know"?
If he installs a drop pitman arm when the spring comes up and the wheel turned to the right will it hit the pitman arm?
Dave ----
OP, If you do move forward getting your truck road worthy again and dump a bunch of money into it, it would not be bad idea to check into Hagerty.
I am in agreement with some other posters, that I don't think what you have is a complete show stopper and it is something that you can work with. There are a number of safety issues that have already been pointed out that should be first on the agenda to fix. As far as the 5.0 that is in there, they can be strong engines and unless you plan to enter tractor pulls, mud races or tow heavy with it, the 5.0 with the right cam and carb tuning should work well. You'll probably need to play with gearing too, but with the bigger tires you're running you should do that regardless of which power plant you go with.
To keep things in perspective, at my family farm we can get away with a single barrel, 318ci in the mid 70s D600 Dodge grain truck hauling full load of grain. And that's the newer "more powerful" grain truck, the other grain truck we use is a '54 Chevy 2 Ton with I think a 240 or 260 inline six. You certainly won't win any races in them, but with the correct gearing they can haul quite the load.
ZF5...hard to find and then $$$, NP-435 (4 speed) is really in all actuality a 3 speed, and granny 1st is not used by most, NOT all, just not me for sure. The none synchronized 1st is like you have to be 100% stopped, clutch all the way on and do not force it. And no real 1st to 2nd under heavy in town acceleration. And NO down shift from 2 to 1 for sure.
Start in 2nd and go with it. As far as the truck advice.... not right or not as it should be to be SAFE, and safe when driving on pavement is what matters. You know the ol bus load of nuns saying...I bet they do not have Hagerty insurance either.
Safe driving at highway speeds is achievable, first thing is to fix the safety issues related to steering and brakes. Make sure the tires are balanced, once you get above 40-45mph with unbalanced tires your teeth will want to rattle out of your head, that was my experience anyway when I tried to run some 35s without any balancing. You could do something similar to what I do on my Harley and that is balancing beads inside the tire. On the Harley I use ceramic beads. For bigger truck tires I think you can get away with BBs or lead shot. There are charts available through web search that show how much weight to add based on tire size.
I have looked into a 5 speed swap. Whether you go with a ZF5, NV4500, M5OD, TR4050 or any other option that may be out there, you will have to do some level of modification and/or find the right adapters for clutch engagement and mating to engine and transfer case. I have a '79 with a T-18 and NP205 considering the same kind of swap.
I have considered Gear Vendors Overdrive. I like the idea of turning my 4 speed with granny gear into a 7 speed. 1st gear will remain as is, for the GV OD to actuate you need to be going a certain speed, which is faster than you can go in 1st gear. 2-4 though you will be able to split with the overdrive unit. 2-2OD-3-3OD-4-4OD, fourth overdrive will actually be an overdrive gear. I don't like that the GV OD mounts to the output of the transfer case and only provides OD in 2wd.
I have seen on the Gear Vendor's website that for custom race applications they offer a overdrive unit that goes between the transmission and transfer case. I haven't reached out to them about that setup, but have given some thought to the idea of getting a custom overdrive unit from them that will replace the tail housing between the trans and xfer. I know this wouldn't work with the current main shaft due to its length, but if I swapped for a main shaft that is shorter in the transmission that it might be possible.
Whether you decide to go with a 5 speed transmission swap or add an overdrive unit it will be an investment of time and money. I think I like the idea of a 7 speed using my original transmission and transfer case combo versus swapping to a newer transmission.
The other thing I am doing due to lack of overdrive is, I am building my engine to run best 2500-3500 RPM, my thought process being those are the RPMs the truck is running at on the highway, I may as well build the engine to make the best power at that RPM level.
I use engine braking quite a bit. I don't use the clutch to shift in most cases too. It's how I learned I guess.
Regarding the shifting and engine braking, when done correctly it is easier on the clutch and brakes. To shift without the clutch you match engine speed to the gear speed. For example, downshifting from 4th to 3rd, blip the throttle a bit and slip out of 4th into neutral. Move shifter towards 3rd apply a little bit of pressure to shift into third, rev engine to match what it would be at whatever speed you're traveling in 3rd gear, when the engine speed matches you'll slip into gear like hot knife through butter. Don't match speeds, well you're grinding until it fits...
By downshifting like that and letting off the throttle you're using the engine compression to slow down, reducing wear on your brakes and since you didn't do anything with the clutch no wear there either.
You can upshift as well, from a stop, let out the clutch get up to speed, where you would normally press clutch and shift, just shift instead, might require a blip of the throttle to unload drivetrain to pull out of gear and a little rpm to slide into next gear. If you are at correct engine and road speed it'll shift just like or better than when you use the clutch. With modern transmissions that are synchronized, you can just jam gears with or without the clutch, older, non-sychronized transmissions your only choice to shift smoothly was to do so matching speeds.
Learn something new everyday.
https://www.summitracing.com/parts/r...=true#overview
