Weirdness after LED installation
Old Oct 5, 2024 | 07:49 PM
WXboy's Avatar
WXboy
Today we installed LED bulbs in my headlights and fog lights on the 2005 F-150. Everything works perfectly with the fog lights turned off. But when we switch the fog lights on it automatically kicks the headlights into high beam and will not allow low beam to be selected. That is extremely weird. It does that regardless of whether there are halogen or LED bulbs in the fog lights. The only way we can get the headlights to work normally is by keeping the fog lights turned off. Does anybody have any ideas why this is happening? By the way the LED bulbs that I'm using are high quality name brand bulbs that were very expensive.
Old Oct 5, 2024 | 08:06 PM
BossHog39's Avatar
BossHog39
having same problem with mine I have not found a solution yet it sucks I can run either one no problem but both goes straight to high beam I am thinking I may need add resistors to now the way you talk with driving lights doing this with halogens to I think the resistors need to go on low beams but again like you said its weird that they trigger high beams
Old Oct 6, 2024 | 07:18 AM
techrep's Avatar
techrep
research the Bambi mod ! this will fix your problem.
Old Oct 6, 2024 | 09:14 AM
WXboy's Avatar
WXboy
I thought the Bambi mod was for newer trucks to allow the fog lights to stay on with the high beams and low beams both?
Old Oct 6, 2024 | 09:56 AM
RLXXI's Avatar
RLXXI
11-14 certain, <10, 15> uncertain. It allows you to use high beams with fog lights. Low beams should work regardless of fog light status.
Old Oct 6, 2024 | 12:25 PM
WXboy's Avatar
WXboy
Then apparently I have an electrical confusion due to the LEDs. Maybe I'll contact the vendor this week and see if they offer resistors.
Old Oct 6, 2024 | 07:30 PM
RLXXI's Avatar
RLXXI
I used 1 of these at every led. https://www.superbrightleds.com/vehi...sh-warning-fix
Old Oct 6, 2024 | 08:13 PM
Papa Tiger's Avatar
Papa Tiger
Led's' screw a lot of stuff. I tried them as brake lights in my wife's car. Couldn't see the lights at mid-day with SOL's light when she braked.
Forget the stupidity. Your life is hanging on it.
Old Oct 6, 2024 | 09:37 PM
Fifty150's Avatar
Fifty150
Try replacing the flasher relay with part no. EP-27. Available at most auto parts stores. You can find them online from Amazon or eBay for half the price.
Old Oct 7, 2024 | 04:59 AM
techrep's Avatar
techrep
thought we were troubleshooting head lights not flashers.
Old Oct 7, 2024 | 07:37 AM
97 Mountain Man's Avatar
97 Mountain Man
The Bambi mod will fix the issue. I did it to my 2004 after installing LED headlight and foglight bulbs.
Old Oct 8, 2024 | 04:35 AM
techrep's Avatar
techrep
tried to tell him that back in post 3.
Old Oct 15, 2024 | 11:06 AM
WXboy's Avatar
WXboy
To update, I was uncertain that the "Bambi mod" would cure this, because that's a mod we do on the newer trucks to allow fogs to stay on with high beams. My issue on the old '05 is that I want to use LOW beams with fogs.
So, I called Headlight Revolution (the vendor I got the bulbs from) and they suggested a set of the GTR Lighting modules that plug in between the bulbs and truck harness. This seems to have totally cured the issue. Will take the truck out after dark tonight to be sure.
rick_johnson
Mar 27, 2021 12:32 AM
truckfella
Modular V10 (6.8l)
Jan 12, 2021 05:00 AM
SD Dually
Oct 25, 2017 08:04 AM
troverman
2015 - 2020 F150
18
Dec 3, 2016 07:17 AM
Ronin007
Escape & Escape Hybrid
13
Jun 2, 2007 09:16 PM
