Fuel Pump Driver Module 2006
Old Oct 4, 2024 | 07:52 AM
TerranE's Avatar
TerranE
Looking at a friends truck. It appears the fault may be the FPDM. Watched a few videos showing it on the frame above the spare. None of the internet pictures I see match what I see under the truck. Its a V6 Triton. F150. I was told a 2006. I just don't see it. I see what looks like a rectangular metal cover with a 2 wire connection and fuel lines going into it just behind the cross member. Comments? Thank you.
Old Oct 4, 2024 | 07:59 PM
Fifty150's Avatar
Fifty150
Originally Posted by TerranE
Comments?
Use the truck VIN. parts.ford.com
Old Oct 5, 2024 | 07:11 AM
techrep's Avatar
techrep
must be an 04 heritage. unless someone modified it and just hard wired it.
Old Oct 5, 2024 | 08:32 PM
TerranE's Avatar
TerranE
Thanks guys. I haven't had a chance to get back at it. Everything looked factory. It just looked different from everything I've seen online and I couldn't locate the module. Possibly an 04. Using the VIN should tell me exactly what I'm dealing with though. I appreciate the advice thank you.
Old Oct 7, 2024 | 10:37 AM
TerranE's Avatar
TerranE
This is where I slink away to a different group. It doesn't have a FPDM as its a 98'. At least its a Ford. I guess I'll check the relays. I appreciate it. Thanks again.
Old Oct 7, 2024 | 01:48 PM
RLXXI's Avatar
RLXXI
Try posting the question in the correct test section for your truck, this is 04-08 section.
Old Oct 7, 2024 | 02:46 PM
TerranE's Avatar
TerranE
I was told that it was an 06'. Searching the VIN# told me different. Not my truck. I usually only work on my own. Learn as I go.
jrp07f
Modular V10 (6.8l)
Jan 27, 2022 10:46 AM
ramhunter5877
2004 - 2008 F150
Aug 6, 2014 11:36 AM
JohnFlow06
2004 - 2008 F150
Jan 9, 2011 10:48 PM
john39
Modular V8 (4.6L, 5.4L)
Oct 19, 2007 07:14 AM
