Sponsored by: Auxito
Only Running on Half the Engine
Old Oct 2, 2024 | 04:45 PM
TimFinnigan's Avatar
TimFinnigan
1st Gear
I got an f250 v8 5.4 liter triton '99 as a quick fix. It had a stuck sparkplug that somebody had j b welded in. I put it back together, and it is only running on the left bank. It has fuel and spark, just won't fire.
Any suggestions? Thanks in advance!
Old Oct 2, 2024 | 05:03 PM
Jon Freeman's Avatar
Jon Freeman
Sounds like the PCM wiring is messed up. Check all your connections.
Old Oct 2, 2024 | 05:45 PM
BareBonesXL's Avatar
BareBonesXL
When you say "fuel" you probably mean the pump is pumping and the rail has fuel in it. Sounds like the injectors aren't opening. I'd check power at the injector plugs. Compare to the side that works. If you have power, noid lights will tell you if the PCM is opening them. If they're not opening, there's something wrong on the PCM side.
Old Oct 3, 2024 | 06:24 PM
Papa Tiger's Avatar
Papa Tiger
Do a Compression test and suspect Cops / spark plugs. Change the relays around, see if it is a bad relay in the fuse box. those also corrode, look for blue / green stuff.
Turn the Air Filter connection cap upside down and spray starting fluid, see if it fires and wants to run. Double check the codes then.
Old Oct 3, 2024 | 08:36 PM
pdqford's Avatar
pdqford
Did you have the head off to fix the sparkplug issue?
If so, I would suspect the one bank is out of time.
Gareth
Aftermarket Products
Jul 31, 2024 06:11 AM
rockher_man
Feb 4, 2009 01:58 PM
frankyford
Dec 14, 2006 08:43 AM
kyyates
Dec 15, 2005 04:05 PM
