distributor gear
Old Oct 1, 2024 | 10:13 AM
56panelford's Avatar
56panelford
distributor gear
I have a 351 W out of a 1995 F150 and have bought a Holley Sniper 2 and their Hyper spark distributor which came with a cast iron gear , I want to confirm if it's a steel gear I need , it's the original cam that I am using. Holley won't make any recommendations regarding using the original gear..
Old Oct 1, 2024 | 11:38 AM
DaveMcLain's Avatar
DaveMcLain
Original gear is a Melonized steel gear. A cast gear won't live on a steel camshaft. A bronze would also work ok.
Old Oct 8, 2024 | 05:36 PM
5851a's Avatar
5851a
Draw a file over it. If it cuts, it's cast if it doesn't its steel. JMO
Old Oct 9, 2024 | 08:31 AM
56panelford
I ended up using the original gear , the one on the Holley distributor was cast..
Old Dec 3, 2024 | 03:12 PM
Glaser67's Avatar
Glaser67
Original steel gear off stock distributor? If so, good. I've made the steel gear on cast cam mistake and the cam was getting eaten up after several thousand miles.
Rusty_S
Nov 11, 2022 01:43 AM
James Wagoner
Oct 8, 2020 02:34 AM
AbandonedBronco
20
Jun 5, 2014 12:22 PM
gnwalker
Jan 23, 2010 11:44 AM
meb9796
Jun 13, 2008 10:35 PM
