Final Charge Global?
Old Sep 29, 2024 | 04:30 PM
Mudshovel40's Avatar
Mudshovel40
Trailering
The past few months I have been trying to figure out what coolant to put in my 7.3. There are so many different opinions that it makes research frustrating and I give up. But I would really like to get a coolant flush done before it gets too cold and I loose motivation.
I think I have decided on Final Charge Global. All I really want to know is if this will be okay for the 7.3 and if any additives need to be put in and if I will need to monitor SCA's.
I plan on following Diesel Hubs write up on doing a coolant flush and will be replacing radiator hoses and and the coolant temp sender (sensor?) as well.
Thanks.
Old Sep 29, 2024 | 04:48 PM
Olds64's Avatar
Olds64
I use Peak concentrated antifreeze I get at Sam's Club. I mix it 33% strength with distilled water and I installed a Wix 24307 coolant filter that's pre-charged with SCAs (a must for a 7.3l, good to have on a 6.9l).
https://www.ford-trucks.com/forums/1...-9-diesel.html
Old Oct 1, 2024 | 08:19 AM
WCMtn1990's Avatar
WCMtn1990
Thanks.
Better than just replacing the coolant temp sender would be to swap it out for a mechanical coolant gauge. I bought an Equus at NAPA for $30 some years back and it worked great. Much nicer to see an actual temp than the factory setup.
GEugeneS
26
Sep 8, 2023 07:32 AM
holyspirit
Jun 1, 2015 11:23 PM
IDI-Charlie
Jan 17, 2014 12:43 AM
Eallend7
Mar 6, 2013 07:27 PM
D.S.
Nov 10, 2004 08:17 PM
