View Poll Results: mud guards...don't want to rip out of metal?
Nothing current, put 3m clear over factory clear higher
11.11%
Mud guards, what kind
16
88.89%
White fender flairs
0%
Voters: 18. You may not vote on this poll
Hey guys, mud flaps?
Old Sep 27, 2024 | 08:02 PM
truckman5000's Avatar
truckman5000
Trailering
Old Sep 27, 2024 | 10:25 PM
fordman19762003's Avatar
fordman19762003
I'd put on flares and mudflaps.
Old Sep 28, 2024 | 03:55 AM
Willard5.0's Avatar
Willard5.0
Factory Ford mud gaurds look great.
Old Sep 28, 2024 | 04:55 AM
Bugzilla46310's Avatar
Bugzilla46310
The factory flaps that came on my truck were too short so I added to them. Wasn’t going to throw brand new flaps away. If it had no flaps, the Duraflaps I had on my 2016 looked new after 7 years. Normally I would order a truck and add flaps but when I went in to order, mine was on the lot, was 95% of what was on my built truck, had all the must haves and wasn’t marked up.
Old Sep 28, 2024 | 05:28 AM
Poncho450's Avatar
Poncho450
I'm on my 5th of these trucks since 2017. I've always used Ford molded mud flaps like Bugzilla posted, but without adding onto them. I like the fit and they've done what I needed.
Old Sep 28, 2024 | 10:08 AM
KU4OJ's Avatar
KU4OJ
Most folks seem to run either Husky or Weather Tech no hole mount mud flaps. I have no preference, really, but mine are Weather Tech I got locally at a good price. Both mount easy in a few minutes. They require no holes to be drilled, since the point is to protect the truck and not poke holes in it. I think they are "comically large" and the do keep the truck clean.
I'm not a big off-road guy. I did find road spray was coating the sides of the truck and the running boards. The OEM running boards on my 2022 are troublesome to get clean once dirty. The mud flaps cured most of the problem. They go through the car wash just fine.
Old Sep 28, 2024 | 12:05 PM
rna352's Avatar
rna352
The poll choices make my head hurt. And I can't quite tell by the pictures but it appears that with those wheels and tires you will have a hard time keeping your truck clean regardless.
For the best looking solution, my vote would be Tremor flares + factory flaps (there is a version meant to work with the tremor flares IIRC).
Old Sep 28, 2024 | 12:10 PM
rna352's Avatar
rna352
My truck came from the factory with holes everywhere. A couple self tappers isn't going to hurt anything.
But this is the internet, and for some reason, lots of folks are afraid of drilling even the tiniest hole in an obscure area.
Old Sep 28, 2024 | 03:45 PM
Summers22's Avatar
Summers22
Bought my 2019 last year and it had Weathertech. I liked them enough to leave them. I did swap out some hardware for stainless though as some bolts/screws were rusted.
Old Sep 28, 2024 | 04:50 PM
stroke250's Avatar
stroke250
Rokblokz
Old Sep 28, 2024 | 08:08 PM
rna352's Avatar
rna352
Originally Posted by stroke250
Rokblokz
I recently put these on my Raptor and I am pleased with their design and effectiveness. Looks like you got the XL version?
Old Sep 28, 2024 | 08:19 PM
stroke250's Avatar
stroke250
Should be one of their standard versions.
https://rokblokz.com/collections/for...-flaps-fr-2017
Old Sep 28, 2024 | 09:08 PM
rna352's Avatar
rna352
Just the camera angle I guess - your front looks quite close to the ground.
Old Sep 28, 2024 | 10:40 PM
stroke250's Avatar
stroke250
this may help.
Old Sep 29, 2024 | 11:26 AM
bigwin56f100's Avatar
bigwin56f100
OEM front and rear along with an across the back hitch mounted unit
