New PCM Idle Issue
Old Sep 27, 2024 | 06:58 PM
Choon77's Avatar
Choon77
3rd Gear
New PCM Idle Issue
Hello all,
I have a 94 F150 with an E40D and a 5.8.
I recently replaced my PCM with a VIN verified unit from Protech Auto in a attempt to resolve a transmission shifting issue.
Unfortunately this did not resolve my shifting issue and my truck has started to fast idle after every start since installing the new PCM. The truck used to fast idle only after the first start of the morning then kick down to about 800 but now it fast idles after every start even after I drive it for a while. The truck still kicks down on its own but I find it strange that this never occurred before.
I know it’s easy to assume that I need to pull the PCM and have it sent back for warranty but I was curious if there is something else that could be at play before I go through that process? I replaced the IAC and the TPS about a year ago and I was not experiencing this issue with the old PCM, although it was very corroded when I removed it.
thanks in advance.
Old Sep 27, 2024 | 10:00 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Sure seems like the reman PCM is causing the problem. Are you getting the same fault codes you had with the old computer plus new ones?
Old Sep 27, 2024 | 10:11 PM
Choon77's Avatar
Choon77
3rd Gear
unfortunately there were no codes being thrown with the old PCM and there are none being thrown with the new one now. The truck is running exactly the same (with the transmission issue) the only difference now is the idle. I’m just wondering if my TPS is out of wack or the new PCM is just junk. It was one of the more expensive services I went through and they guaranteed a bench test before sending it out that’s the only reason I was searching for alternatives.
Old Sep 28, 2024 | 06:05 AM
My4Fordtrucks
None at all? Not even the system pass code? What lead you conclude that the old computer was bad? Why did you replace the TPS? Test the new part to see if has failed. Did the “new” PCM have the same engineering number on the sticker as your old PCM?
Old Sep 28, 2024 | 03:22 PM
Choon77's Avatar
Choon77
3rd Gear
I pulled the old PCM to inspect it and it was heavily corroded from the caps leaking, that’s why I ordered the new one. The new PCM was programmed directly off of my Vin and old PCM part number, I provided them to the rebuilder. I replaced the TPS in an attempt to solve my shifting issue because I understand that idle can affect the transmissions normal operations, but it also provided no relief.
Old Sep 28, 2024 | 05:27 PM
My4Fordtrucks
The computers are preprogrammed from the factory. They are not programming them in house from your VIN. It isn’t like an OBD-II computer that you flash to update it. So are you getting the system pass code or not?
BRex69
1978 - 1996 Big Bronco
53
Nov 6, 2021 01:00 PM
loud41
Nov 4, 2019 09:08 AM
DPDISXR4Ti
Mar 21, 2013 01:33 PM
hawkrdr
Dec 25, 2009 01:03 AM
pdlpwr
1983 - 2012 Ranger & B-Series
43
Sep 3, 2005 06:47 PM
