Fluids - Diff, Manual Transmission, Transfer Case
Old Sep 26, 2024 | 08:04 PM
turtleheadtim's Avatar
turtleheadtim
1974 F250 Highboy
realizing I should probably check and change these fluids.
I've found with this truck, what I'd expect to use isn't always the case.
So, what fluids for:
Diffs
Manual Transmission
Transfer Case
thanks!
Old Sep 26, 2024 | 09:48 PM
mterickson's Avatar
mterickson
Originally Posted by turtleheadtim
1974 F250 Highboy
Diffs
Manual Transmission
Transfer Case
thanks!
80W90 or similar weight for all of those. Make sure whatever you put in the transmission is good for brass synchronizers. Some GL5 rated gear oils will corrode soft metals for example.
I use 75W90 Royal Purple synthetic gear oil in mine and is compatible with the transmission synchros.
Old Sep 26, 2024 | 10:57 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
1974 F250 Highboy realizing I should probably check and change these fluids. I've found with this truck, what I'd expect to use isn't always the case.
Diffs
Manual Transmission
Transfer Case
thanks!
Differential: yes 80/90 gear lube.
Manual trans 80/90 but read up on the other threads below. Also T-18 or NP-435 trans?
Transfer case, it is a NP-203 or a NP-205? Because it matters, 203 gets like 30 wt motor oil and a 205 gets 80/90
Good info here from fellow members. https://www.ford-trucks.com/forums/1...ion-fluid.html
And: https://www.ford-trucks.com/forums/1...-capacity.html
Or: https://www.ford-trucks.com/forums/1...4-highboy.html
Old Sep 27, 2024 | 11:45 AM
turtleheadtim
I’ve got 2 gallons of this Lucas diff fluid…
is the wording on the label suggesting it’s safe on yellow metals? Or best not to chance it?
google AI says yes… do we trust google Ai?
Old Sep 27, 2024 | 11:54 AM
turtleheadtim
Oh, and transfer case is np205
anything I should note there?
beyond the gear oil note?
Old Sep 27, 2024 | 11:56 AM
mterickson's Avatar
mterickson
According to their product data sheet it is safe with soft yellow metal. Data sheet is attached.
File Type: pdf
samuel4wolfpack
Oct 10, 2024 09:48 AM
Youngbuck47
Mar 2, 2021 06:30 PM
Bluegrassboy70
Sep 3, 2009 11:29 PM
Grey89F250
Apr 16, 2008 10:31 PM
