Oil pump drivesaft
Old Sep 26, 2024 | 07:23 PM
w951wxj's Avatar
w951wxj
Oil pump drivesaft
I have a 73 302 I'm building. Got most of the engine assembled. Oil pump drive shaft..new hardened shaft ingot gas a washer/lock on it...which way does drive shaft go in.
Old Sep 26, 2024 | 08:08 PM
DaveMcLain's Avatar
DaveMcLain
The washer goes toward the end that sticks into the hole in the block.
Old Sep 26, 2024 | 08:45 PM
cougrrcj's Avatar
cougrrcj
The reason for that is the washer will hit the block casting, preventing the shaft from pulling up out of the pump and falling back down into the oil pan when the distributor is removed (that tends to be a major 'oopsie' )
Old Sep 27, 2024 | 11:14 AM
w951wxj's Avatar
w951wxj
OOOH - Nice to know - thanks. I did see a bunch of people talking about dropping the shaft into the oil pan..guessing that does not flow out the drain hole too easily...ha
projectbad78
Jul 19, 2008 02:57 PM
maddmaxx29
Nov 19, 2006 08:04 PM
allen410
Nov 24, 2004 10:26 PM
F150Conno
Apr 25, 2004 11:10 PM
wckdclwn911
Apr 21, 2004 07:23 AM
