Sponsored by: Real Truck
Limited slip in reverse??
Old Jan 14, 2003 | 02:07 PM
REKEPPEL's Avatar
REKEPPEL
Does limited slip work when your F250 is in reverse? We have a 2003 PSD and I had a difficult time backing out of a yard on muddy grass. It was just a slight grade and the right rear wheel just spun and spun. I thought the other wheel should take over when this happens. I guess with the 7.3L there is just too much weight up front.
Old Jan 14, 2003 | 02:22 PM
FortyFords's Avatar
FortyFords
Just touch the brake pedal lightly next time!if its and auto.
should work it has for me in the past
If its a 4x pull the lever
Rich
02 F250 4x4 SC 5.4v8 6spd 3.73ls Trueblue/Silver and Chrome Nerfs
"All Levers"
Old Jan 14, 2003 | 10:52 PM
chassis's Avatar
chassis
The short answer to the question is yes, LSD works in reverse. It's a wet clutch pack inside the rear axle differential, and is bi-directional.
Good advice on tapping the brakes to get better LSD function.
Old Jan 15, 2003 | 10:09 AM
Quikirk's Avatar
Quikirk
Old Jan 15, 2003 | 10:46 AM
abendx's Avatar
abendx
there has been a lot of talk in the past regarding the amount and quality of the lubricant that ford used in the diffs. you might want to check the levels and/or replace the oil with a more suitable type.
most ppl that have done one or both of the above have reported MUCH better operation of the stock LSD. do a search and see the full discussions.
or... if you want to spend a few bucks... get a detroit locker and 'forgetaboutit' !
Old Jan 15, 2003 | 04:21 PM
superduty2003's Avatar
superduty2003
superduty, with tires and stuff... bwaahahaha, rotflol, lmao!!!!! That's the funniest signature i've seen! lol, oh, sorry, not tech, BUT FUUUUUUUNY!
Old Jan 15, 2003 | 04:55 PM
abendx's Avatar
abendx
hummm.... everyone here takes all my seriousness and makes fun... even the new guys :-X23
Old Jan 15, 2003 | 06:08 PM
deboernj's Avatar
deboernj
I can't seem to find anything in a search about this. If anyone runs across info please post.
Old Jan 15, 2003 | 06:43 PM
abendx's Avatar
abendx
oh crap... is the search feature still down????
hummm.... sorry, u'll have to manually look...
Old Jan 15, 2003 | 06:47 PM
deboernj's Avatar
deboernj
Any idea if those posts were in this forum or one of the others?????
2003 F250 4x4 CC Lariat, SB, V10, Moonroof, Power everything!
Old Jan 15, 2003 | 06:51 PM
abendx's Avatar
abendx
sorry... it was a while ago
i would guess in this forum or the offroad or the suspension forums.
you might also look in the oil forum as that is where it SHOULD be.
might want to look over at ford-deisel.com too... they prob have posts on this.
Old Jan 15, 2003 | 06:57 PM
deboernj's Avatar
deboernj
>forums.
>SHOULD be.
>have posts on this.
I'll do some digging and post what I find. Thanks
Old Jan 16, 2003 | 02:02 PM
deboernj's Avatar
deboernj
OK, Here's a few of the past threads that addressed these issues..
https://www.ford-trucks.com/dcforum/DCForumID117/4537.html
https://www.ford-trucks.com/dcforum/DCForumID117/4128.html
https://www.ford-trucks.com/dcforum/DCForumID117/3672.html
Looks like the answer is:
Make sure your clutch packs are in good shape, (less then 50K they're probably OK)
Make sure you have the right oil w/ the proper additives, (Check your manual or talk to a reliable dealer)
Use your parking brake if you need the LS to kick in when not moving,(they're designed to function when both wheels are spinning)
Kick out the dollars for a Detroit Locker
Good luck and happy spinning!!!
2003 F250 4x4 CC Lariat, SB, V10, Moonroof, Power everything! (and yes, a LS rearend)
Old Jan 16, 2003 | 03:36 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
>are spinning)
This is a misnomer.
What you really need is PRELOAD on the clutches. Load makes the diff spider gears want to seperate from each other, applying more pressure to the clutches.
To get that preload, you have to hit the brakes (or parking brake) and apply some power. It will usually get you more lock-up from the stock LS as long as the clutches aren't glazed.
art k.
Old Jan 16, 2003 | 03:54 PM
deboernj's Avatar
deboernj
>>are spinning)
>This is a misnomer.
>glazed.
>art k.
Thanks Art,
Sounds reasonable, I never did understand quite how it works, just that it does.
