Flathead tuning
Old Sep 23, 2024 | 06:47 AM
Popastruck's Avatar
Popastruck
5th Gear
Flathead tuning
Hey all. I need some help. I have a 1953 8ba rebuilt 30 over with 4” crank Max 1 cam Offy aluminum heads and Speedway three duece intake with 3 super 97 carbs and progressive linkage. Timing is 6 degrees initiall and 32 total all in by 2900 rpm. When I hook up the vacuum gauge the needle is erratic at idle (600 rpm) if I increase the rpm to say 900 the gauge evens out around 18. If I increase idle to 750 the needle waves between 14 and 18. There seems to be a slight miss sound at the tail pipes. Sorry about the long explanation but I don’t know what to do next?
Old Sep 23, 2024 | 08:46 AM
ALBUQ F-1's Avatar
ALBUQ F-1
32° is way more advance than a flathead needs, 22° - 24° total at 2000 - 2200 RPM is usually best (mechanical + initial, vacuum disconnected).
I assume you have some kind of electronic ignition with both mechanical and vacuum advance? What vacuum advance source are you using, manifold vacuum? If you have an adjustable vacuum advance diaphragm, shoot for around 10° max vacuum advance.
Old Sep 23, 2024 | 09:00 AM
Popastruck's Avatar
Popastruck
5th Gear
Yes. Pertronix distributor with there coil. No vacuum advance hooked up. I will have to set up the max advance yet but just trying to get this running a little better. It starts good and drives down the street and back okay. Just can’t get a steady vacuum reading. Vacuum is from manifold under back carb
Old Sep 23, 2024 | 11:04 AM
hooler1's Avatar
hooler1
How aggressive of a cam are you running? With a larger cam you may need more initial timing, with less throttle, and maybe a somewhat leaner setting of your idle mixture screws. If you use more initial timing you will be using less mechanical advance to get to your "all in" timing. Such as (just an example here) if you get the smoothest idle at let's say 10 degees initial, and your max advance should be 22, then you will need only 12 degrees of mechanical advance to get to an "all in" timing of 2000 RPM. So with a aftermarket distributor like a Pertronix, you will need to play with your advance springs and advance limiters to give you your timing "curve". This does not include using manifold vacuum though. Once that is connected then the distributor advance changes and you may need to go back again and compensate for that.
Another thing to kind of keep in mind is the crank damper. Sometimes the outside rim slips, and the timing marks are no longer accurate. It might be a good idea to see if the 0 TDC mark is truly showing TDC.
Old Sep 24, 2024 | 09:08 AM
Truckfarm's Avatar
Truckfarm
Yep, what hooler1 says about camshaft. Big, long duration cams have a lumpy idle. The overlap of both intake and exhaust valves being open at low rpm cause this along with poor vacuum. Air / fuel mixture takes time to flow, so big cams account for this by opening valves sooner and closing later to get more mixture in the cylinder at high rpm where max horsepower can be developed. Listen to cars at the drag strip. New cars with variable valve timing are trying to get best of both low and high rpm power. So, see if you have the lift and duration specs for your cam shaft.
Old Sep 24, 2024 | 11:06 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Max-1 isn't a wild cam
Old Sep 28, 2024 | 02:22 PM
Popastruck's Avatar
Popastruck
5th Gear
So I did a little more checking on my flathead. Linkage was not working properly. Now both front and rear cars are closing all the way. I disconnected linkage so just dealing with main carb for now.
The miss or popping is from cylinder #4. If I pull cyl 4 plug wire the miss or popping goes away? There is good spark at the plug. Any ideas?
Old Sep 28, 2024 | 04:26 PM
hooler1's Avatar
hooler1
I was sort of wondering about the slim possibility of cross fire between plug wires 5 and 4. With the plugs being as far away from each other I wouldn't think that would be an issue, but if the 5 and 4 wires aren't crossed over-under each other, IF there is a small amount of paralell run, it might be a possibility. The link below talks about running flat head wires in the conduits they had. He also mentions something about using a certain brand of plug wire with a Pertronix set up. Might be some good information for you there (assuming you haven't seen it before).
The only other thing maybe a damaged spark plug or a bad wire. Might be interesting to try a different wire and plug.
https://myflatheadford.com/routing-s...ires-in-looms/
Old Sep 28, 2024 | 04:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Look at the plug end of #4 wire, inside the boot. I had one where the terminal was just touching the core of the wire, it had been crimped on but came out while putting the boot on/off the plug. If you have suppression type wires that can happen pretty easily. At least it was easy to fix, too. The end at the cap can do that too. You might also check the resistance of the wire over its full length, could be a break in it.
Old Sep 28, 2024 | 04:56 PM
charlie g's Avatar
charlie g
FTE Community Team
why 3 =2's 8bas run better on 2 only , 3 i've long found over fueled them merc 4 inch crank = old school cheating 255 inches
Old Sep 28, 2024 | 05:26 PM
Popastruck's Avatar
Popastruck
5th Gear
I will have to look at those ideas next week. Looking after the grand daughter this weekend. 3 x 2 carb setup is what came as part of the package deal I got on the motor
Old Sep 29, 2024 | 05:41 AM
charlie g's Avatar
charlie g
FTE Community Team
thyme look good but after 60 years of building them 2x2 has always run and worked better
Old Sep 29, 2024 | 12:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1
A big 2-barrel or a 4-barrel works better than either, but you run what you've got.
Old Sep 29, 2024 | 04:00 PM
charlie g's Avatar
charlie g
FTE Community Team
hear that, a old holley pisspot off a y block works and looks cool
Old Oct 1, 2024 | 07:52 AM
mtflat's Avatar
mtflat
Did they ever get quality control improved on those Super 97s? When they first came out they were very unreliable. If this is an old set-up that might come into play.
