Truck wont start.
Old Nov 29, 2003 | 05:55 PM
Ming's Avatar
Ming
Truck wont start.
Like and idot I washed 1989 f-250 351 engine and now it wont start. I put fuel in the throttle body and it will run. But it is not getting feul. Should I get a comp scanner and if so whats the best brand for alot of models, or should I start looking at somthing ealse. I am not very good with cars so make it easy lol. thks
Old Nov 29, 2003 | 06:12 PM
black874x4's Avatar
black874x4
It could be a fuel pump relay stuck.
Old Nov 29, 2003 | 07:20 PM
marragtop's Avatar
marragtop
I agree... could be the fuel pump relay stuck because you washed the engine. When you turn the key to the 'on' position, you should hear the fuel pump run for a second or two. If not, then you're not getting fuel to the motor.
Old Nov 29, 2003 | 08:08 PM
Ming's Avatar
Ming
SO where is this relay at. Is it the things behind the air intake filter.
Old Nov 29, 2003 | 10:10 PM
Darctangent's Avatar
Darctangent
fuel pump relay is in the engine compartment fuse box (relays are bigger than fuses and all in a row to one side) let me know if you still have trouble I can look on my 93' for a better discription.
-Scott
