electric window repair
Sep 17, 2024 | 04:17 PM
window wont go up when it's @ 1/2 way or lower... any advise on how to fix it?
Sep 17, 2024 | 04:28 PM
Do you hear the window motor?
Sep 17, 2024 | 05:05 PM
yes - its just not catching
Sep 17, 2024 | 05:32 PM
Likely the plastic bushings inside the gearbox have disintegrated.. that is a commn failure on these. You can buy those online for a few bucks and rebuild the gearbox or you could just replace the whole motor/gearbox assembly, it's almost the same amount of work either way. There are videos for how this is done online.
Sep 17, 2024 | 05:36 PM
Sep 17, 2024 | 06:05 PM
Yes. Replacing the gear in the window motor is an easy and cheap repair.
Sep 17, 2024 | 11:14 PM
Window motor inserts: Doorman 74410
Sep 18, 2024 | 12:19 PM
Quote:
Originally Posted by
seschenburg
There aren’t any bushings in my ‘87 Bronco window motor and since the OP didn’t mention year I wouldn’t assume that is the right part.
Sep 18, 2024 | 12:27 PM
I was just looking at his picture. Looks like a 3rd or 4th generation. Could be wrong though.
Sep 18, 2024 | 02:39 PM
seschenburg
I think you meant 8th or 9th generation F-Series. It appears to be a 9th generation (‘92-96) to me but is that same truck with the window problem?
Sep 18, 2024 | 02:48 PM
Yeah. Sorry. Dyslexia kicking in a little hard today. You are correct.
Sep 18, 2024 | 03:28 PM
Window motor
I have found 1/4” nuts in place of the pucks that disintegrate in those motors.
Sep 18, 2024 | 03:29 PM
First thing I learned from the boys at the Lincoln store
You can fix those disintegrated drives using high side AC caps (the smaller plastic ones)
Save yourself the money for the new drive
Take it apart and cram 3 a/c caps in there
50 cent repair
Sep 18, 2024 | 03:51 PM
"high side AC caps (the smaller plastic ones"
what are these and where do you get them?
Sep 18, 2024 | 04:08 PM
Caps for the high pressure port on an R-12 a/c system. If I remember correctly, R-134a would be way too big.
