Inside Door Surface Rust
Old Sep 16, 2024 | 11:00 PM
Green72F250's Avatar
Green72F250
I'm looking for information on how to remove the surface rust inside the truck door. I have used steel wool and a wire brush, but some of the places around the door hinges are difficult to access. Any suggestions are appreciated. Thanks
Old Sep 17, 2024 | 06:06 AM
BobbyFord's Avatar
BobbyFord
Sand blast.
Old Sep 17, 2024 | 06:21 AM
FuzzFace2's Avatar
FuzzFace2
Got a picture of what you are dealing with so we can see and come up with something.
Dave ----
Old Sep 18, 2024 | 06:32 AM
davelj's Avatar
davelj
Consider a liquid rust converter you can spray in the hard to access areas. I like them for use in cracks and crevices that blasting can't reach.
Old Sep 18, 2024 | 09:07 PM
1browski's Avatar
1browski
I had surface rust in my doors on my 72 f250 as well. I ended up wire brushing anything loose and then brushing on a rust converter. Later I sprayed primer in the doors and then a rubberized undercoating and called it good.
Old Sep 18, 2024 | 09:35 PM
Green72F250
Thanks for the inputs!! Has anyone used Ospho as a rust converter? Does it work good?
Old Sep 19, 2024 | 07:47 AM
McPoindexter's Avatar
McPoindexter
Trailering
muriatic acid is the best but you got to really be careful using it
Old Sep 21, 2024 | 11:30 AM
BobbyFord's Avatar
BobbyFord
The problem with the acid is that it needs to be either rinsed or neutralized after application. Rinsing just promotes more rust.
Old Sep 21, 2024 | 11:52 AM
McPoindexter
Trailering
well I rinse with vinegar then water dry with compressed air and dry clean rags right after rinsing apply DuPont metal prep then prime scuff dry primer and paint.
44 years ase certified auto body tech
Dupont certified painter 1989
Old Sep 21, 2024 | 04:15 PM
BobbyFord's Avatar
BobbyFord
Ospho works, too.
https://www.skybryte.com/about.php
BGF100
May 6, 2019 08:00 PM
fordinmudd
1997 - 2003 F150
Mar 26, 2018 05:08 AM
eneusiis
2009 - 2014 F150
Jun 20, 2017 11:48 AM
jvmcc
May 31, 2014 04:04 PM
maverickman514
Mar 6, 2011 09:40 AM
