Steering Problems
Old Nov 29, 2003 | 03:44 PM
bigjob's Avatar
bigjob
Question Steering Problems
I have an issue with my stock steering in my 55 f100. While making a left turn, it seems to jerk the wheel pretty bad. Turning right I have no problems, just turning left. It is bad enough I quit making long trips to shows because I just did not want to take a chance.
I pulled the steering box apart and did not notice any major problems or wear. I also adjusted it and didn't make much difference either.
Anyone experience this before? I certainly dont want to throw money at it.
Old Nov 30, 2003 | 02:22 AM
gtkane's Avatar
gtkane
Bigjob;
Try greasing the kingpins-my guess is that the right hand side is a little sticky or dry.
Graham
Old Nov 30, 2003 | 01:58 PM
bigjob's Avatar
bigjob
Graham
Thanks for the advice. I will add that to my winter maintenance.
Old Nov 30, 2003 | 02:25 PM
29abone's Avatar
29abone
Bigjob, per chance, could you have wide tires that interfere with the drag link when you turn left??
Old Nov 30, 2003 | 06:07 PM
tp's Avatar
tp
Bigjob, I had exact same prob and the guys here helped me narrow it to the draglink. It had a broken spring. Also, steering arm ball was so worn it had become oval. Terry
Old Dec 1, 2003 | 08:27 AM
bigjob's Avatar
bigjob
29abone, I do run wider tires, but I purchased 1" offset rims to eliminate that problem. Thanks
TP, Thanks for the information. I just purchased rebuild kits for the draglink at fall Carlisle.
BigJob
