View Poll Results: 1989 302 hard to start after warm
Any Ideas
0%
Need quick help truck used for work
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Slow start after running 20m
Old Nov 29, 2003 | 11:39 AM
timchi56's Avatar
timchi56
Angry Slow start after running 20m
About 4 months ago someone stoled my stereo from my truck, since then my truck will start up perfectly but once it gets warm its like the battery is dead until it sits for about 30m.
I repaired the damage from the stolen radio and capped all the cut wires. I have changed the starter, relay, battery, all battery cables including the the starter, someone suggested a heat shield for the starter, which I installed. I changed the key switch also, the only thing left is the ignition switch and module which is costly.
Anyone have any ideas or have a similar problem in the past money is getting tight with Christmas around the corner. I cannot afford to make many mistakes regarding parts that won't fix the problem.
Thanks for any insight,
Old Nov 29, 2003 | 05:11 PM
WALJON's Avatar
WALJON
I had that problem F250 4x4 351W this went on for a year ended up being poor oil pres. bad oil pump.
Old Nov 29, 2003 | 05:31 PM
ajstephan's Avatar
ajstephan
I'm not sure I understand the problem completely. Does your truck lose all power after running for 30 minutes, or does the starter just not crank after being parked for 30 minutes?
If it won't crank after 30 minutes, than it could be the solenoid. You can use a crank trigger to cut across the solenoid to see if that's the problem. Also, this could be a symptom of a bad starter. I had this happen on a Pontiac of mine years ago. If the starter motor stopped in a certain positition after running for a while, it wouldn't crank until it cooled off. One way to get it cranking is to have a friend turn the key while you whack the starter with a hammer. I know, it sounds bad, but it works, and I've heard mechanics recommend this as well. You'll have to replace the starter anyway.
Regarding the starter motor you replaced, a rebuilt starter is no guarentee it works. Have them test the starter *under load*. It's tough to find a place that will do that, but getting a motor to spin freely is a lot easier than getting to spin 6 to 8 cylinders. I made the shop replace the starter 3 times until they gave me a good one.
Old Nov 30, 2003 | 01:41 AM
timchi56's Avatar
timchi56
It would appear the problem has been fixed. The ground wire was lose from the battery to the engine. I'm not sure why it would not work when warm before. This had gone on for 5 months with no letting up. A few turns to tighten the ground wire and all seems fine, I drove the truck all over today with no problems at all.
I have no clue what or why this worked.
Thanks to everyone for your insight.
