CEL Reduced Engine Power
Old Sep 3, 2024 | 10:00 AM
jeffgreenx's Avatar
jeffgreenx
Was towing the 5th wheel over the holiday weekend, and at one point, relatively flat interstate, my check engine light came on with the message "Reduced Engine Power". The truck never slowed down or seemed to have any lack of power. I was towing at 70 mph, but slowed it down a little for the rest of the drive home. This has never happened before. Outside temps were warm (around 90), but engine/oil/transmission temps all seemed to be within normal ranges. I've since driven to work and had the engine started a few times. The light persists, but no noticeable change in driving performance. Haven't had a chance to pull a code yet, but will do right after work today. My stupid local dealer is 2 months out on service appointments.
Thoughts? Thanks in advance!
2018 6.7L CCSB
Old Sep 3, 2024 | 10:08 AM
cpobst's Avatar
cpobst
Do you have a CEL also or just "reduced power" message? How's your DEF level?
Old Sep 3, 2024 | 10:34 AM
jeffgreenx's Avatar
jeffgreenx
CEL is lit up still. The reduced power message only popped up once when the CEL first came on. DEF is 2/3 full.
Old Sep 3, 2024 | 11:07 AM
Jorgem2's Avatar
Jorgem2
I recently had a reduced power CEL and some other Knox sensor codes and it was a bad battery.
once batteries were replaced everything dissapeared
Disconnect Check both batteries first
Old Sep 3, 2024 | 12:01 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You have to get the code read, can't tell anything without it.
Either go to the parts store and get them to scan it for you, or buy a scan tool and do it yourself.
Anything anyone says without the code is purely guessing, hundreds of possible causes for your issue.
T406
Jul 25, 2023 08:08 AM
teach23666
Mar 15, 2019 07:39 PM
Alan Burns
6.7L Power Stroke Diesel
Jun 1, 2017 09:07 AM
Aaron116713
May 14, 2017 06:25 PM
SRO63
Modular V8 (4.6L, 5.4L)
Apr 10, 2017 08:17 PM
