Glow Plug Controller
Old Nov 29, 2003 | 09:51 AM
AlienMotorsports's Avatar
AlienMotorsports
HI I have a 1993 f350 N/A 7.3, my problem is it is hard starting but the bigger problem is, when i turn the ignition on, it heats the plugs and the "wait to start light turns off" but then I try to start it, and the glow plug controller/heater is ticking on and off and the gauges are jumping on the dash, what could be wrong, im new to diesels, is this normal? should it be doing this? Or is the reson im hard starting and having a continuous ticking because the controller is bad? also....when it does eventually start, the ticking continues for a few more seconds, thanks for any help, i really appreciate it.
Old Nov 29, 2003 | 10:15 AM
GregA's Avatar
GregA
Re: Glow Plug Controller
...is this normal? should it be doing this?
Yes, and yes.
http://home.comcast.net/%7Eargve1/glow_plug_system.html
Check your glow plugs.
Old Nov 29, 2003 | 11:53 AM
kidoo's Avatar
kidoo
You are lucky, mine does not click all the time, it keeps heating the plugs. I am afraid I will burn them. I will have to change the controller.
Yes the clicking is normal.
Old Nov 30, 2003 | 03:06 PM
AlienMotorsports
Thanks alot guys, I really appreciate it, next questions, does anyone has a 93 f350 7.3? Reason is, I need a picture of the fuse setup under the hood, I dont know what amp's of fuses go where, thanks alot again.
Old Dec 1, 2003 | 10:47 AM
dburke8088's Avatar
dburke8088
AlienMotorsports, I have '93 F350 7.3. I just finished replacing my Glow Plugs. (A vetran of cylinder 3) Check the glow plugs first. Easyer than replacing them. Use a 12 light and connect one side to the positive on your battery. Then MAKE SURE YOU REMOVE THE ORIGINAL GLOW PLUG CONNECTOR FIRST! Touch the other side of your light to the top of the glow plug. It should light very brightly. Anything else is a dead plug. If you have over 50% dead plugs, replace them all! As far as the fuses, the lid for the fuse bos) are correct. Which fuse box do you need the image of?
Old Dec 1, 2003 | 03:56 PM
AlienMotorsports
Thanks alot for all the info, the fuse box I need the picture of, is the one under the hood on the drivers side wheelwell, the cover doesnt say which amprage it needs, thanks for all your help again, also do you ahve a chat service on the computer we can talk through? thanks alot
