How many miles do you guys have on your trucks ?
#4546
Just stopping by, been a while since I've read this forum. My 2015 has 168,000 right now, it'll be 170,000 by the end of the week. We have a '14 with 180,000 and a '16 with 10,000.
I've needed a radiator, batteries, and the cac pipe. I've got the wobble issue. I added 2.5° caster to the front and it still does it so I may need other suspension parts. Makes me want to go with kelderman......
#4548
#4550
#4557
milage
I got my 2017, June 30th. 942 miles. I love this thing. The power is very
impressive. It's just flat out fun to drive. Mine is the XL. Not a ton of electronics etc. But I got what counts to me. Lots of room. 4wd. v8 motor.
Pull 10 k pounds . tow haul. All for 4 thousand less than an f 150 and
probably 9-10 less than a diesel, which I wanted, but did not need.
#4558
still goingggggggg !
2002 f-350 4x4 triton V10
now at 205,000 miles..... and knock on wood still no major issues..did replace all the steering linkages... it helped the steering but still wanders a bit..could be because I didn't replace the steering box.
mileage sucks... 9.3 gallons per mile... and dropping it seems... also appears to be using oil... I will say its the best truck i've ever owned !
when was almost new it went through sandstorm... and was re clearcoated...which is now starting to peel off the hood. and driver seat is worn through the leather and some of the foam is missing.
Quote:
Originally Posted by 79 F250 4XoVeRu View Post
2002 f-350 4x4 triton V10 .... 175,000
gone through a few sets of tires... replaced an alternator, had plug blow out at 80k
other than that nothing other than normal maintenance ...
except this past week I did replace upper and lower ball joints...wow what a difference !
its been a great truck... and when clean it still looks pretty new
original post was 01-23-2014
UPDATE .....now at 191,000 and still no issues...just replaced battery for second time since truck was new. about 2yrs ago replaced ball joints. needs tie rod ends and related replaced now....wanders a little on the freeway.
also still have the original u joints in it.
haven't replaced wheel bearings yet .. never heard of wheel bearings going 191k before...amazing how things last longer now. mileage has gone from 12 to about 9... and have done all other normal maintenance.
#4560
