Hardware Override Automatic Engine Stop?
Old Aug 29, 2024 | 07:44 PM
AZFordLover's Avatar
AZFordLover
The manual (pg 203) says:
"You can stop the engine shutdown, or reset the timer, at any point before the 30-second countdown has expired by doing any of the following:
• Pressing the brake pedal or accelerator
pedal.
• Pressing the OK or RESET button
during the countdown."
If I put a brick on the brake pedal, will the truck idle until it runs out of fuel?
I had a close call today with my precious cargo (4-legged) after about 2 hours of idling - came back to the truck after 2:15 and the truck was off. Fuel gauge showed a full tank. Fortunately, it wasn't much above 80 in the cab (A/C set to 63) so no harm done but I can't trust the stupid little software switch any more.
I'm looking for a hardware-based, 100% certain solution to this automatic engine stop "feature."
Open to other ideas.
Old Aug 29, 2024 | 08:05 PM
AZFordLover
NVM - I think I found one.
Old Aug 29, 2024 | 08:55 PM
24SuperDuty's Avatar
24SuperDuty
5th Gear
pedal.
https://merlinsfab.com/site/2023/12/02/idle-on/
Old Aug 29, 2024 | 08:57 PM
AZFordLover
Originally Posted by 24SuperDuty
Thank you - a bit rich for my blood, though.
A little more googling found this - BD Diesel's similar one seems to be getting good reviews on various forums: HIGH IDLE CONTROL FORD 6.7L POWER STROKE F-SERIES SUPERDUTY F250 / F350 / F450 / F550 / F600 2023+ | 1036613
Old Aug 30, 2024 | 07:55 AM
BC2019F250's Avatar
BC2019F250
Why would you need to leave the pet in the truck for 2 hours? I work in a campground where someone left their 2 dogs in their RV for 8 hours on a 90 degree day. Unfortunately, their air conditioner quit working and both animals died.
I would never leave a pet in a vehicle or RV.
Old Aug 30, 2024 | 08:50 AM
CBEllis's Avatar
CBEllis
Okay Judge Judy...hey - he's looking for a way to lengthen or disable the shut-off at idle, not input on what he does and where with his pets or cargo.
@AZFordLover if you use the Ford Pass app, I'm almost positive there is a way to add time to the idle settings while the truck is running. It's a pain to remember to go in and add time, but I do think it's possible. And, maybe @ZooDad knows of a way to completely disable in ForScan - that would be nice.
Old Aug 30, 2024 | 10:32 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
All the setting are there, it just does not work.
still looking into it though.
ZooDad
tcanthonyii
Nov 30, 2023 11:05 AM
thrasher141
Aug 24, 2023 08:24 PM
Stevereeves
Mar 13, 2019 10:19 PM
snknby123
28
Jul 11, 2014 03:23 PM
Nathan C
6.4L Power Stroke Diesel
May 27, 2007 02:04 PM
