Towing query
Old Aug 29, 2024 | 02:06 AM
Nitestlkr's Avatar
Nitestlkr
3rd Gear
Towing query
High i am curious and seeking knowledge. I have a 99 F550 that is my personal vehicle. It is not registered as commercial.. I need suggestions and advice on how i can legally use this truck to pick up and tow my 99 freightliner fld 120 from california to oklahoma.. i am not really wanting to spend thousands to have someone else tow it for me. i have called all the states that i will be traveling thru and they said it could legally be done but said they could not tell me how as they hadnt seen it done before. So any advice is welcomed.
Old Aug 29, 2024 | 06:54 AM
SpencerPJ's Avatar
SpencerPJ
Are you planning to put it on a trailer?
Old Aug 29, 2024 | 08:42 AM
Nitestlkr's Avatar
Nitestlkr
3rd Gear
I was considering either a trailer or piggy backing it.
Old Aug 29, 2024 | 10:56 AM
OBS460's Avatar
OBS460
You simply just do it. If you get pulled over by DOT you tell them everything is personal use so leave you alone. Tell them there is a reason you have personal use registration and no DOT numbers on your doors. Pull out an invisible log book and pretend to hand it to them and say here are my logs for my commercial operation.
Don't ask for permission from the government to do what you have an inalienable god given right to do, moving your property across state lines for personal use.
Old Aug 29, 2024 | 11:10 AM
Nitestlkr's Avatar
Nitestlkr
3rd Gear
I appreciate your response. I was planning on do that anyways but figured I'd ask others for advice n the case someone had any insight on this if they had been n a similar situation but definitely am gonna move it
Old Aug 29, 2024 | 07:56 PM
GLR's Avatar
GLR
As mentioned, you're not commercial so it should be OK.
Have a safe and successful trip.
Old Aug 30, 2024 | 03:57 PM
senix's Avatar
senix
Yup, towing it home but take the fastest direct route out of california.
Your only real issue is the speed limit for towing in california is 55 mph. But you will probably get passed by others towing at that speed.
tseekins
2015 - 2020 F150
17
Jan 5, 2017 02:26 PM
Supercab
1997 - 2003 F150
Aug 11, 2012 08:22 AM
jbirdsvt
Feb 21, 2005 10:03 AM
bucks-heritage
3.8 & 4.2L V6
31
Aug 23, 2004 01:38 PM
fireball69
1997 - 2003 F150
Mar 10, 2004 02:28 PM
