Sponsored by: Real Truck
no start
Old Aug 28, 2024 | 04:59 PM
olyellow's Avatar
olyellow
no start
I have an 2000 f350 with a 6.8 liter engine it has been sitting for about 5 years I changed out the fuel pump fuel filter and have good fuel pressure but it will only run when you spray something into the air cleaner any help
Old Aug 28, 2024 | 05:14 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
So, you have fuel and you have spark (runs on ether). Where did you check fuel pressure from?
I would think crank shaft and camshaft sensors next. I would also suggest you download FORSCAN next. It's a very handy diagnostic tool.
Old Aug 28, 2024 | 05:18 PM
Eman85's Avatar
Eman85
What is the good fuel pressure? Are the injectors working?
Old Aug 28, 2024 | 06:15 PM
olyellow's Avatar
olyellow
I checked fuel pressure at the fuel rail and Iam getting 45psi checked with noid lights and getting a signal
Old Aug 28, 2024 | 08:10 PM
Eman85's Avatar
Eman85
Injectors clicking?
Old Aug 28, 2024 | 09:09 PM
projectSHO89's Avatar
projectSHO89
Sounds like the injectors ain't injectin'.. Probably clogged, gummed up, or the fuel is sour.
It's unlikely anything is wrong with the cam or crank sensors. If there was, it wouldn't fire or run on starting fluid.
Old Aug 29, 2024 | 06:58 PM
99f350sd's Avatar
99f350sd
Pull a bank of injectors and see if clogged etc working.
254partsguy
Mar 18, 2023 09:11 PM
Totally Tuna
Nov 21, 2018 08:07 AM
coloradojeep1
Nov 23, 2017 06:57 PM
Roland Donnell
Texas Chapter
Nov 16, 2004 11:08 AM
Roland Donnell
Modular V8 (4.6L, 5.4L)
Nov 14, 2004 10:13 AM
